在PrCube 4.1更新1中创建“自定义自定义配置文件”的PDF没有棱镜组件
如何获得棱镜并将其安装到PrC造作4.1更新1中? 以上来自于百度翻译 以下为原文 PDF on "Creating a BLE Custom Profile" in PCreator 4.1 update 1 has no PrISM component How do I get a PrISM and install it into PCreator 4.1 update 1? |
你想用哪个芯片?棱镜组件需要一个LFSR来操作,这可能已经被移除了?
据我所知,Psoc Creator 3.3是它支持的最后一个版本;如果您绝对需要使用它,请尝试实现自己的组件/软件做相同的事情,或使用旧的创建者版本。 以上来自于百度翻译 以下为原文 Which chip are you trying to use it on? The Prism component requires a LFSR to operate, which might have been removed? Psoc Creator 3.3 is the last version it is supported on as far as I can tell; If you absolutely need to use it, try implementing your own component/software that does the same thing, or use the older creator version. |
你好,
PROC(可编程无线片上)器件不具有棱镜组件,它是基于UDB(通用数字块)的组件,而PROC设备不具有UDB。您可以选择PSoC家族的任何其他部分(右键点击PSoC Project & GT;设备选择器),您甚至可以在PC 4.1中找到这个组件。 谢谢。 以上来自于百度翻译 以下为原文 Hello, PRoC (Programmable Radio on Chip) parts of devices do not have PrISM component which is a UDB( Universal Digital Block) based component and PRoC device does not have UDB. You can select any other part of PSoC family( Right Click on the PSoC project-> Device selector) and you will be able to find this component even in PC 4.1. Thanks. |
754个成员聚集在这个小组
加入小组2111 浏览 1 评论
1858 浏览 1 评论
3673 浏览 1 评论
1792 浏览 6 评论
1540 浏览 1 评论
579浏览 2评论
432浏览 2评论
442浏览 2评论
391浏览 2评论
978浏览 2评论
GMT+8, 2024-12-29 11:34 , Processed in 0.591845 second(s), Total 75, Slave 59 queries .
