嗨,
我下载了安装了可执行文件Xilinx_SDSoC_2017.1_sdx_0623_1_Win64的SDSoC,但是当我打开安装的程序时,它是SDx而不是SDSoC。 我很担心,因为我也尝试使用2016.4版本,它做了同样的事情。 SDx没有能力进行SDSoC估算,所以我更喜欢使用SDSoC。当我启动exe文件时,我会看到“SDx IDE 2017.1安装程序”窗口,为什么不是SDSoC安装程序? 当我必须选择开发环境时,我选择了SDSoC平台。 任何人都有同样的问题,可以帮我弄清楚该怎么办? 以上来自于谷歌翻译 以下为原文 Hi, I downloaded SDSoC with the executable Xilinx_SDSoC_2017.1_sdx_0623_1_Win64, installed it, but when I open the program installed, it's SDx and not SDSoC. I'm worried because I tried it also with the version 2016.4 and it did the same thing. SDx doesn't have the capacity to do SDSoC estimation, so I would prefer using SDSoC. When I launch the exe file I get the window "SDx IDE 2017.1 Installer", why isn't it the SDSoC Installer ? When I have to chose the Development Environments I chose SDSoC Platforms. Anyone got the same problem and could help me figure out what to do ? |
4个回答
我实际上在其他社区帖子中找到了答案。
在这里,如果有人需要它:https://forums.xilinx.com/t5/SDSoC-Development-Environment/SDSoC-2016-2-no-SDEstimate-option-exists-for-build-configuration/td-p/ 711207 在原帖中查看解决方案 以上来自于谷歌翻译 以下为原文 I actually found an answer in some other community post. Here it is if someone needs its : https://forums.xilinx.com/t5/SDSoC-Development-Environment/SDSoC-2016-2-no-SDEstimate-option-exists-for-build-configuration/td-p/711207 View solution in original post |
在2016.3左右的某个时间(我不记得确切的版本),SDSoC和SDAccel工具合并为一个名为SDx的工具。
SDx安装具有运行这两个工具的功能,所选择的工具基于您在创建项目时选择的平台。 www.xilinx.com 以上来自于谷歌翻译 以下为原文 Sometime around 2016.3 (I can't recall the exact release), the SDSoC and SDAccel tools were merged into a single one called SDx. SDx install has the capability to run both tools and the one that is chosen is based on the platform you chose when you create a project. www.xilinx.com |
谢谢你的答案!虽然,为什么我在选择Build Configurations - > Set Active时没有第三种可能性“Estimation”?
我只有发布和调试,即使我有最新版本的SDx,我在安装过程中选择了SDSoC(我有一个微板)。 以上来自于谷歌翻译 以下为原文 Thank you for the answer ! Though, why don't I have the third possibility "Estimation" when choosing Build Configurations -> Set Active ? I only have Release and Debug, even though I have the latest version of SDx and I chose SDSoC during the installation (I have a microzed board). |
我实际上在其他社区帖子中找到了答案。
在这里,如果有人需要它:https://forums.xilinx.com/t5/SDSoC-Development-Environment/SDSoC-2016-2-no-SDEstimate-option-exists-for-build-configuration/td-p/ 711207 以上来自于谷歌翻译 以下为原文 I actually found an answer in some other community post. Here it is if someone needs its : https://forums.xilinx.com/t5/SDSoC-Development-Environment/SDSoC-2016-2-no-SDEstimate-option-exists-for-build-configuration/td-p/711207 |
2448 浏览 7 评论
2846 浏览 4 评论
2310 浏览 9 评论
3391 浏览 0 评论
2486 浏览 15 评论
1773浏览 1评论
623浏览 1评论
485浏览 1评论
2036浏览 0评论
762浏览 0评论
GMT+8, 2025-1-13 07:19 , Processed in 1.154368 second(s), Total 51, Slave 45 queries .
