电子发烧友william hill官网
扫一扫,分享给好友
嗨伙计,
在我的PC Vivado设计套件2015.2和SDK 2015.2工作,但只有vivado HLS 2015.2没有打开,这就是为什么我想重新安装Vivado HLS 2015.2。 如何下载Vivado HLS 2015.2评估版。 请建议我或分享我链接。 谢谢和最诚挚的问候 Vinod Sajjan 以上来自于谷歌翻译 以下为原文 Hi Folks, In my PC Vivado design suite 2015.2 and SDK 2015.2 is working but only vivado HLS 2015.2 is not opening, that is why i want reinstall Vivado HLS 2015.2. How to download the Vivado HLS 2015.2 evaluation version. Please suggest me or share me Link. Thanks and Best Regards Vinod Sajjan |
@vinodsajjan
“Xilinx设计工具”下的“添加设计工具或设备”窗口菜单项不允许您这样做。 Vivado和Vivado HLS将被检查并变暗 - 只有设备可用于安装/卸载。 你怀疑,你必须再次卸载并安装所有内容。 如果您遇到一致的问题,也许应该下载整个安装程序而不是运行Web安装程序。 vitorian.com ---我们这样做很有趣。 总是给予赞誉。 如果您的问题得到解答,请接受解决方案。我不会回复个人信息 - 请改用william hill官网 。 以上来自于谷歌翻译 以下为原文 @vinodsajjan The "Add Design Tools or Devices" windows menu item under "Xilinx Design Tools" won't let you do that. Vivado and Vivado HLS would be checked and dimmed - only devices would be available to install/uninstall. You would have to uninstall and install everything again, I suspect. If you are having consistent problems perhaps you should download the entire installer instead of running the web installer. vitorian.com --- We do this for fun. Always give kudos. Accept as solution if your question was answered. I will not answer to personal messages - use the forums instead. |
嗨,
我不确定您是否可以单独下载Vivado HLS,因为安装程序对整个Design Suite来说都很常见。 您可以做的只是卸载Vivado HLS,然后启动Vivado并从“帮助 - >添加设计工具或设备”重新安装HLS。 但它假设问题来自安装而不是下载。 此外,您在主机上使用哪个操作系统? 我遇到了类似的问题然后意识到2015.2版本不支持Windows 10。 希望你能解决问题, 宝莲 以上来自于谷歌翻译 以下为原文 Hi, I'm not sure you can download Vivado HLS independently, because the installer is common to the entire Design Suite. What you could do instead is uninstall only Vivado HLS, then start Vivado and reinstall HLS from "Help -> Add Design Tools or Devices". But it assumes the problem comes from installation and not download. Besides, which OS are you using on your host machine? I ran into a similar problem and then realized 2015.2 version does not support Windows 10. Hope you'll solve the problem, Pauline |
2424 浏览 7 评论
2826 浏览 4 评论
2294 浏览 9 评论
3375 浏览 0 评论
2465 浏览 15 评论
1241浏览 1评论
590浏览 1评论
453浏览 1评论
2008浏览 0评论
732浏览 0评论
GMT+8, 2024-12-25 17:03 , Processed in 1.257258 second(s), Total 80, Slave 64 queries .
