是德科技
李茜
7年用户 167经验值
使用labview远程控制E5061B检测到内部错误
嗨,我们正在开发用于远程控制E5061B的labview应用程序(LV2011)。
我们还使用可用的ENA系列仪器驱动程序。
通常应用程序按预期运行,但问题在E5061B检测到内部错误时启动。
预期的测试进度是开始扫描。
如果仪器检测到错误,我们希望中止扫描并使用更正的设置开始新的扫描。
问题是当检测到内部错误时,仪器似乎被通信阻塞,它没有正常响应。
我们可以使用“master reset”命令吗?
如果有人能给我som建议解决问题,我会很高兴吗?
关于Oddgeir
以上来自于谷歌翻译
     以下为原文
  Hi,
We are developing a labview application (LV2011) for remote controlling E5061B.
We also use the available ENA series instrument drivers.
Normally the application functions as intended, but the problem start when E5061B detects an internal error.
The intended test progress is to start a sweep. If the instrument detect an error, we want to abort the sweep and start a new sweep with a corrected setup.
The problem is that the instrument seems to be communicationally blocked when it have internal error(s) detected, it not responding normaly.
Is there any "master reset" command that we could use?
I will be happy if anyone could give me som advise to solve the problem?
regards
Oddgeir
回帖(2)
蒋进如
2018-12-27 16:31:33
william hill官网
以上来自于谷歌翻译
     以下为原文
  forum
贾永世
2018-12-27 16:38:21
亲爱的Oddgeir虽然我不确定NI Labview控制,如果你可以用SCPI命令与E5061B通信,“* RST”是预置命令。
如果您遇到Labview应用程序或驱动程序通信问题,请咨询NI的支持william hill官网 。
以上来自于谷歌翻译
     以下为原文
  Dear Oddgeir
Although I am not sure about NI Labview control, if you can communicate to E5061B with SCPI command, "*RST" is preset command.
If you have a trouble of Labview application or driver communication, please ask NI's support forum.
