> {quote:title = kalai写道:} {quote}>我正在评估E5061B 75欧姆分析仪。我无法从keysight网站找到内部框图。
>基于以上内容我在框图下面有几个问题。任何人都可以帮我这个吗?
> E5061B 75欧姆分析仪是否使用内部50-75欧姆有损匹配垫将50欧姆转换为75欧姆?
>或者分析仪内部使用的所有组件都是75欧姆设备吗?
只有Keysight的某个人才能确认。
但基于我见过的其他75欧姆分析仪,大多数内部都是50欧姆,但桥接器是75欧姆。
使用内部50-> 75欧姆焊盘会对性能造成相当大的影响,所以我怀疑他们会这样做。
但是你需要让Keysight的某个人给你一个明确的答案。
戴夫
以上来自于谷歌翻译
以下为原文
> {quote:title=kalai wrote:}{quote}
> I am evaluating E5061B 75 Ohm Analyzer.I am not able to locate the internal block diagram from keysight website.
> Based on the above i have few questions below on the block diagram.Can anyone help me on this?
> Does the E5061B 75 Ohm Analyzer use an internal 50-75 Ohm lossy matching pad to convert the 50 Ohm to 75 Ohm?
> Or does all the components used inside the Analyzer are 75 Ohm devices?
Only someone from Keysight will be able to confirm it for sure. But based on other 75 Ohm analyzers I have seen, most of the internals are 50 Ohms, but the bridge is 75 Ohms. The use of internal 50->75 Ohm pads would compromise the performance quite a bit, so I doubt they would do that.
But you will need to get someone from Keysight to give you a definitive answer.
Dave
只有Keysight的某个人才能确认。
戴夫
以上来自于谷歌翻译
以下为原文
Dave
