断电后,保证内存擦除需要多长时间?假设2秒的VCC达到0VDC。
以上来自于百度翻译 以下为原文 After power off, how long does it take for guaranteed memory erase? Assume 2 seconds for VCC to reach 0VDC. |
嗨,请告诉我,如果你正在做一个背靠背掉电和SRAM设备的电源。因为一旦电源断开,数据就无法保证,一旦再次上电,就会有一些垃圾数据。所以,我想知道为什么需要时间来保证内存擦除。问候,Pavan
以上来自于百度翻译 以下为原文 Hi, Please tell if you are doing a back to back power down and power up of the SRAM device. Because, once the power is off, there is no guarantee for the data and there will be some garbage data once you power on again. So, I want to know the reason for requirement of the time it takes for guaranteed memory erase. Regards, Pavan |
754个成员聚集在这个小组
加入小组2110 浏览 1 评论
1858 浏览 1 评论
3673 浏览 1 评论
1791 浏览 6 评论
1540 浏览 1 评论
575浏览 2评论
428浏览 2评论
439浏览 2评论
389浏览 2评论
921浏览 2评论
GMT+8, 2024-12-26 17:38 , Processed in 0.865741 second(s), Total 78, Slave 62 queries .
