扫一扫,分享给好友
当PSOC5被释放用于样品时,哪个零件号将是第一个被释放的?
以上来自于百度翻译 以下为原文 When the PSoC5 is released for samples, which part numbers will be the first to be released? |
8个回答
PSoC 5发布的第一部分将cy8c5588axi-060(100tqfp超集部分)。然后紧随其后将相同的超集参与68qfn和48ssop包。谢谢!吉姆
以上来自于百度翻译 以下为原文 The very first part number for PSoC 5 that is released will be the CY8C5588AXI-060 (100TQFP) superset part. Then following shortly behind will be the same superset part in the 68QFN and 48SSOP packages. Thanks! Jim |
我多久能得到一个CY8C5688 AXI-060的样品?
以上来自于百度翻译 以下为原文 How soon can I get a sample of the CY8C5588AXI-060? |
我有从树供应商的ARM7的经验。作为最终用户,我期待PSOC5 ARM有一个专门的PIN(不是多功能PIN),如果我们要使用串行下载或JTAG,我们使用它来告诉ARM。这在NX*和ANALO*ARM的情况下工作良好,但是在一个发光体*臂的情况下失败。在这种类型的PIN多功能的情况下,您可能无法解锁设备,取决于您已经选择了该PIN的功能。
以上来自于百度翻译 以下为原文 I have experience with ARM7 from tree vendors. As end-user I'm expect that PsoC5 ARM has an dedicated pin (not multifunction pin) that we use to tell to ARM if we going to use Serial Download or JTAG. This works well in case of NX* and Analo* ARMs, but fail in case of an Luminar* ARMs. In case of multifunction for that kind of pin, it can happened that you can't unlock device, depend on function that you have select for that pin. |
我还不知道我们什么时候会看到这些设备。我不太关心什么时候我会看到一个样本,我想知道什么时候我会看到一个开发/初学者工具包。
以上来自于百度翻译 以下为原文 I see there is still no news about when we will actually see these devices. I'm not so concerned with when I will see a sample, I want to know when I will see a development/starter kit. |
PSOC 5试剂盒和样品将在5月底全部上市。
以上来自于百度翻译 以下为原文 The PSoC 5 kits and samples will all be available by the end of May. |
你好,
PSoC5启动套件在这里,但没有设备,没有样品的设备,没有迹象表明他们的价格和可用性。 有人能在这里洒点亮光吗? 简 以上来自于百度翻译 以下为原文 Hi, PSoC5 Starter kit is here, but no devices, no samples of devices and no indication about the their price and availability. Can someone please shed some light here. Jan |
PSOC 5样品现已通过销售和销售。
2个部分可用于采样:CY8C589AXI-060ES1和CY8C568LTI-114ES1。 我们还有3个包含PSoC 5的套件:HTTP://wwwyCysP.COM/?ID=2218 CY8CITK-01 PSoC Developement Kit CY8CKIT-010 CY8C55系列处理器模块(为客户购买CY8CKIT-00之前包含PSoC 5) CY8CKIT-014 PSoC 5 FirstTouch Starter Kit 以上来自于百度翻译 以下为原文 PSoC 5 samples are available now through distribution and sales. 2 parts are available for sampling: CY8C5588AXI-060ES1 and CY8C5588LTI-114ES1. We also have 3 kits that contain PSoC 5: http://www.cypress.com/?id=2218 CY8CKIT-001 PSoC Developement Kit CY8CKIT-010 CY8C55 Family Processor Module (for customer who bought the CY8CKIT-001 before it contained PSoC 5) CY8CKIT-014 PSoC 5 FirstTouch Starter Kit |
757个成员聚集在这个小组
加入小组2130 浏览 1 评论
1872 浏览 1 评论
3690 浏览 1 评论
1808 浏览 6 评论
1554 浏览 1 评论
624浏览 2评论
473浏览 2评论
460浏览 2评论
413浏览 2评论
1102浏览 2评论
GMT+8, 2025-1-28 06:37 , Processed in 0.868501 second(s), Total 61, Slave 54 queries .
