你好,
我在面对电子墨水显示器的同时面临着一些问题。它的SPI(奴隶)为基础的显示模块与附加引脚的状态。 我已经编辑了SCB SPI主机示例,但无法读取状态响应。在我的示例应用程序和数据表的显示模块供您参考。我想我错过了一些愚蠢的事情。你能帮帮我吗? 顺便说一句,我也成功地连接显示器使用我们的existingble芯片。 谢谢和问候, 沙朗 用于Eink显示的PSOC 1.9兆字节 以上来自于百度翻译 以下为原文 Hello, I'm facing some issues while interfacing with an E-Ink display. Its SPI(slave) based display module with an additional pins for the status. I've edited the SCB SPI master example, but unable to read status response. Attached the my example app and also data sheet of the display module for your reference. I think I'm missing something stupid. Can you please help me? Btw, I did successfully interfaced the display using our existing BLE chip. Thanks & Regards, Sharan |
9个回答
你用什么针连接电子墨水?端口和引脚为P2Y1,用于忙,P2Y2用于启用。
鲍勃 以上来自于百度翻译 以下为原文 What Pins have you connected to the e-ink? Port and pin as P2_1 for Busy and P2_2 for Enable. Bob |
嗨,鲍伯,
是的,P2(1)分别用于繁忙和P2(2)分别启用。这就是你的意思? 附上的图片,我圈的GPIOPTS/PIN用于繁忙和启用。 顺便问一下,你检查了SPI主控组件吗?我做得对吗? 谢谢和问候, 沙朗 德文 2.3兆字节 以上来自于百度翻译 以下为原文 Hi Bob, Yes, P2[1] for busy and P2[2] for enable respectively. This is what you meant? Attached the picture in which I circled the GPIO ports/pins used for the busy and enable. Btw, did you check the SPI master component? Am I doing it correct? Thanks & Regards, Sharan
嗨,鲍伯,
我在这里漏掉什么东西吗?我对PIN感到困惑。我只是连接GPION DEV Boad和显示模块之间的电线。我不懂别针,对不起。 谢谢和问候, 沙朗 以上来自于百度翻译 以下为原文 Hi Bob, Am I missing something here? I'm confused about pins. I'm just connecting the wires between the GPIO on the dev board and display module. I don't understand the pins sorry. Thanks & Regards, Sharan |
在CydWR视图中,您将真正的GPIO引脚分配到您的TopDead页面上使用的符号名称。8个GPIO引脚驻留在一个“端口”上。我从你那里得到的项目是使用GPIOS,这些GPIOS不能按照你指定的方式连接,但是你打开了“锁销”函数。因此,钳工可以分配不同于你选择的其他GPIOS。
我的问题是:你用SPI(MISO,MOSI和SSS)用了哪些针?不要圈他们,只写PXYY 鲍勃 以上来自于百度翻译 以下为原文 In .cydwr view you assigning real GPIO pins to your symbolic names used on your topdesign page. 8 GPIO pins are residing on a "port". The project I got from you was using GPIOs that could not be connected as you specified, but you left open the "lock pin" function. So the fitter could assign, differently from your choice, other GPIOs. My question was: Which pins did you use for SPI (MISO, MOSI and sss)? Do not circle them, just write Px_y Bob |
嗨,鲍伯,
好的,我把电线连接到显示屏上: 味噌:P01 MOSI:P0O0 CLK:P0O3 SS:P02 因此,钳工可以分配不同于你选择的其他GPIOS。 如何知道实际分配的GPIO? 但是现在当我把它们锁在CYDWR上时,我得到了下面的注释。我不知道他们是什么意思。 信息:MPR.M0553:来自设计范围的资源PIN编辑器的信息已经重写了“SPIM:SCLKYM(0)”的控制文件条目。(App= CysFIT)信息:MPR.M0553:来自设计范围的资源PIN编辑器的信息已经重写了“SPIM:MISOOMIM(0)”的控制文件条目。(App= CysFIT)信息:MPR.M0553:来自设计范围的资源PIN编辑器的信息已经重写了“SPIM:Msisim(0)”的控制文件条目。(App= CysFIT)信息:MPR.M0553:来自设计范围的资源PIN编辑器的信息已经重写了“SPIM:SS0UM M(0)”的控制文件条目。(APP=CysFIT) 谢谢和问候, 沙朗 以上来自于百度翻译 以下为原文 Hi Bob, Okay, I'm connecting the wires to the display as follows: MISO: P0_1 MOSI: P0_0 CLK: P0_3 SS: P0_2 >> So the fitter could assign, differently from your choice, other GPIOs. How Do I know which GPIO are actually assigned? But now when I lock them on the .cydwr I get the following Notes. I'm not sure what they mean. Info: mpr.M0053: Information from the design wide resources Pin Editor has overridden the control file entry for "SPIM:sclk_m(0)". (App=cydsfit) Info: mpr.M0053: Information from the design wide resources Pin Editor has overridden the control file entry for "SPIM:miso_m(0)". (App=cydsfit) Info: mpr.M0053: Information from the design wide resources Pin Editor has overridden the control file entry for "SPIM:mosi_m(0)". (App=cydsfit) Info: mpr.M0053: Information from the design wide resources Pin Editor has overridden the control file entry for "SPIM:ss0_m(0)". (App=cydsfit) Thanks & Regards, Sharan |
如何知道实际分配的GPIO?在一个成功的3xSub构建之后查看.CydWR视图。
信息:MPR.M0553:来自设计范围的资源PIN编辑器的信息已经重写了“SPIM:SCLKYM(0)”的控制文件条目。(APP=CysFIT)这只是一个注释,通知您使用的其他引脚比默认的要多。 鲍勃 以上来自于百度翻译 以下为原文 How Do I know which GPIO are actually assigned? Look into the .cydwr view after a succe3ssful build. Info: mpr.M0053: Information from the design wide resources Pin Editor has overridden the control file entry for "SPIM:sclk_m(0)". (App=cydsfit) This is just a note and is informing you that you are using other pins than defaulted. Bob |
嗨,鲍伯,
我检查了CydWR,端口和引脚与默认的完全相同。 附加屏幕截图供参考。 谢谢和问候, 沙朗 波士顿公司 1.1兆字节 以上来自于百度翻译 以下为原文 Hi Bob, I checked the .cydwr, the ports and pins are exactly same as the default ones. Attaching the screen shot for your reference. Thanks & Regards, Sharan
不要把打开的“锁销”函数锁起来,否则每次你建立或运行你的应用程序时,不同的插脚将被PSoC Creator的钳工分配。你可以通过钳工来查看哪个引脚被分配给CydWR。
以上来自于百度翻译 以下为原文 Do not leave the open the "lock pin" function.Lock them otherwise every time you will build or run your application, different pins will be assigned by fitter in PSoC Creator.You can look which pins are assigned by going to .cydwr by fitter. |
你好,
是的,我已经试过锁定这些端口了。但没有任何区别。我也没有观察到自动分配不同的端口后建造的,我总是看到相同的端口引脚。 谢谢和问候, 沙朗 以上来自于百度翻译 以下为原文 Hi, Yes I already tried locking the the ports. But didn't make any difference. Also I've not observed the auto assigning to different ports after the build, I always see the same ports and pins. Thanks & Regards, Sharan |
754个成员聚集在这个小组
加入小组2110 浏览 1 评论
1858 浏览 1 评论
3673 浏览 1 评论
1791 浏览 6 评论
1540 浏览 1 评论
576浏览 2评论
430浏览 2评论
440浏览 2评论
390浏览 2评论
957浏览 2评论
GMT+8, 2024-12-28 15:31 , Processed in 0.895732 second(s), Total 90, Slave 74 queries .
