我需要用MOSFET Irf740做PWM,但是我很难实现PSoC CY8C9466。我正在使用PSoC设计器最新版本,但是开发正在PSoC Express中进行。我等待答案,谢谢。
以上来自于百度翻译 以下为原文 I need to do a PWM with MOSFET IRF740, but I have difficulty to implement the PSoC CY8C29466. I'm using PSoC Designer latest version, but the development is being in PSoC Express. I await answers, thank you. |
4个回答
您好,请告诉我您在执行上述申请时遇到了什么问题。我会尽力帮助你度过难关的。
以上来自于百度翻译 以下为原文 Hello, Please let me know what kind of problems you are facing in implementing the above mentioned application. I'll try to help you in getting through this. |
嗨,我需要控制一个直流电动机,12V的4A与一个Irf740 MOSFET自己通过调制脉冲宽度。我的困难是使用PSoC Express来实现PWM的全部实现,但是软件PSOC设计器5.5或是带有系统级项目的Word。先谢谢你,等待你的帮助。
以上来自于百度翻译 以下为原文 Hi, I need to control a DC motor, 12V 4A with a IRF740 MOSFET OWN through a modulating pulse width. My difficulty is to make all the implementation of PWM using PSoC Express, but with the Software PSoC Designer 5.5 or words with System Level Project. Thank you in advance and wait for your help. |
在系统级解决方案中,我们在输出驱动器列表中有PWM。您可以选择12V,5A高侧具有可变占空比开关MOSFET开/关或调节电机的速度。为了控制占空比,你可以有一个电位器。我附上了一个实现同一事物的示例项目。
以上来自于百度翻译 以下为原文 In the System Level solution, we have PWM in the output driver list. You can select 12V, 5A High Side with variable duty cycle to switch the MOSFET ON/OFF or to regulate the speed of the motor. For controlling the duty cycle, you can have a POTENTIOMETER. I have attached an example project which implements the same thing. |
好吧我会尝试写词和控制发动机,所以你的反应是。我不知道我是否已经调整的时钟与一个按钮,我试过了,但当我按相同,在1分钟的增量,但当它被释放,它减少了,回到基线。如果你能帮助我,我将非常感激。
以上来自于百度翻译 以下为原文 Ok I'll try to write to the CI and control the engine, so you respond as it was. I wonder if I have to adjust the RTC with a button, as I tried, but when I press the same, increment in 1 minute, but when it is released, it decreases, returning to baseline. If you can help me, I am very grateful. |
754个成员聚集在这个小组
加入小组2110 浏览 1 评论
1858 浏览 1 评论
3673 浏览 1 评论
1791 浏览 6 评论
1540 浏览 1 评论
575浏览 2评论
429浏览 2评论
440浏览 2评论
390浏览 2评论
930浏览 2评论
GMT+8, 2024-12-27 13:19 , Processed in 0.896419 second(s), Total 82, Slave 66 queries .
