嗨,我希望你能帮助我,我有一个34970A,我配置了RS232输出波特率:57600数据大小:8流量:XON / XOFF相同的配置在RS232适配器:端口COM13当我打开安捷伦连接专家和我
使用自动检测添加仪器他向DNS发送信号* RMT *出现在界面中他无法配置34970A他告诉请求怎样才能帮助我? 以上来自于谷歌翻译 以下为原文 Hi i hope that u can help me i have a 34970A and i have configured with RS232 output Baud rate :57600 Data size : 8 Flow: XON/XOFF the same configuration in the RS232 adaptator : port COM13 when i open Agilent connection expert and i make add instrument with autodetect he send the DNS a signal *RMT* appear in the interface and he can't configure the 34970A and he tell pleas how can help me?? |
我有同样的问题,发现我必须有COM1作为接口。
如果您没有COM1,请进入设备管理器并检查它是否显示COM1接口。 如果它没有显示其他设备选项,请单击该选项并搜索驱动程序。 当我这样做时,它添加了一个COM1接口。 然后它找到了34970A。 57600是一个非常高的波特率,可能会导致34970A出现问题。 尝试9600.这对于34970A而言足够快。 以上来自于谷歌翻译 以下为原文 I had the same problem and found that I had to have COM1 as the interface. If you don't have COM1, go into the device manager and check if it shows a COM1 interface. If it doesn't but does show an Other Devices selection, click on that and search for a driver. When I did this, it added a COM1 interface. Then it found the 34970A. 57600 is a very high baud rate and could cause problems with the 34970A. Try 9600. That's more than fast enough for the 34970A. |
1307 浏览 0 评论
2382 浏览 1 评论
2203 浏览 1 评论
2074 浏览 5 评论
2958 浏览 3 评论
1159浏览 1评论
766浏览 0评论
967浏览 0评论
1308浏览 0评论
GMT+8, 2025-1-1 21:07 , Processed in 1.393771 second(s), Total 78, Slave 62 queries .
