扫一扫,分享给好友
嗨,我正在通过RS-232将34970A连接到笔记本电脑(Windows XP)。
我的笔记本电脑上的连接专家识别出34970A,我可以与之交谈。 然而,当我试图在Benchlink Data Logger 3上找到它时,它找不到它。我在笔记本电脑上的配置(通过设备管理器设置):波特率9600数据位8Parity NoneStop位1Flow控制Xon / XoffI确保它匹配 34970A的设置(停止位除外,如果重要则为idk)。 可能导致问题的原因是什么?我感谢任何帮助。 以上来自于谷歌翻译 以下为原文 Hi, I am connecting a 34970A to a laptop computer (windows XP) through RS-232. The connection Expert on my laptop identifies the 34970A, and I can talk to it. However, when I try to find it on Benchlink Data Logger 3, it fails to find it. The configuration I have on the laptop (set through device manager): Baud rate 9600 Data bits 8 Parity None Stop bits 1 Flow control Xon/Xoff I made sure it matches the 34970A's settings (except for stop bits, idk if they matter). What could be causing the problem? I appreciate any help. |
3个回答
嗨,我有一个类似的问题,在这篇文章中。“数据记录器无法找到仪器,但IO连接专家可以通信”我正在运行相对干净的Windows 7 Pro,SP1,32Dell E5410串口连接安装
I / O Gear USB到SerialI按照这篇文章的说明,但没有找到我的问题的解决方案.Comm Expert就像一个冠军,但不管我做什么我都无法让Data Logger 3找到34970A.Any帮助 我将不胜感激。最重要的是,JBB 以上来自于谷歌翻译 以下为原文 Hi, I have a similar problem to the one in this post. "Data Logger Can’t Find Instrument but IO Connection Expert Can Communicate" I'm running relatively clean install of Windows 7 Pro, SP1, 32 Dell E5410 Serial port connection on an I/O Gear USB to Serial I followed the instructions from this post, but found no solution to my problem. Comm Expert works like a champ, but no matter what I do I can't get Data Logger 3 to find the 34970A. Any help would be appreciated. best regards, JBB |
尝试更新到最新版本的Agilent IO Libraries。
请访问agilent.com/find/iosuitedownload。 以上来自于谷歌翻译 以下为原文 Try updating to the latest version of the Agilent IO Libraries. Go to agilent.com/find/iosuitedownload. |
如果这不起作用,您可以尝试:通常以下步骤解决问题.1。Unistall software.2.uninstall Agilent I / O.3。重新安装Agilent I / O.4。现在重新安装BLDL SW回到这台机器上
。 以上来自于谷歌翻译 以下为原文 If that doesn't work you can try this: Normally the followings steps solves the problem. 1.Unistall software. 2.uninstall Agilent I/O. 3.Reinstall Agilent I/O. 4.Now Reinstall BLDL SW back on this machine. |
1311 浏览 0 评论
2385 浏览 1 评论
2203 浏览 1 评论
2079 浏览 5 评论
2963 浏览 3 评论
1180浏览 1评论
767浏览 0评论
982浏览 0评论
1312浏览 0评论
GMT+8, 2025-1-4 15:26 , Processed in 1.131858 second(s), Total 49, Slave 44 queries .
