专家好:
我使用adv7441A 采集DVI/HDMI信号。PORTA采集DVI信号,PORTB采集HDMI信号 当使用porta采集DVI信号时,可以正常识别并采集到信号。但是使用portb采集HDMI信号时,portb无法探测到信号。 我使用的是内部共用edid模式(ksv 0x73:0x06)。但是portb无法探测到hdmi信号。但是我将hdmi信号接显示器,可以正常显示。 hw文档提到配置port b的edid需要配置spa_location、spa_portb,请问spa_location、spa_portb如何配置??? 请专家帮忙讨论下,port b无法探测hdmi信号的原因?? 谢谢!!!!!! |
4个回答
先分析EDID里物理地址在哪里放着, 比如放在0X91等, 然后就把0X91写到SPA LOCATION里去, 还要把具体的PORT B的物理地址写到相应的寄存器上去;
原始的EDID是给PORT A的, PORT B与PORT EDID的不同之处在于物理地址的值不一样(物理地址在EDID MAP中所放的位置是一样的),还有BLOCK1 的CHECKSUM,这些您都需要检查一下。 |
yweyerwq 发表于 2019-3-11 17:31 您好! PORTB的物理地址如何确定,我现在设置的spa_location(0x72):0x82,spa_portb(0x70):0x01. 但是还是无法探测到信号,将HDMI信号转换为DVI信号,接porta,接口a可以采集信号。 以下是我的配置,专家帮忙看下,为什么端口B无法探测信号??谢谢~~~ __raw_writeb(0x3,HPDCT);//DISABLE HDMI/DVI HPD write_add_hdmi(0x1,0x68);//disable port a/b clock write_add_ksv(0x73,0x0);//disable edida/edidb write_add_hdmi(0x0,0x1);//选择端口b write_add_hdmi(0x41,0x50); write_add_hdmi(0x15,0x0);//关闭audio write_add_hdmi(0x1C,0x0);//关闭audio write_add_ksv(0x70,0x1);//spa_portb write_add_ksv(0x71,0x0);// write_add_ksv(0x72,0x82);//spa_location write_add_edid//写edid 128字节 { 0x00 ,0xFF ,0xFF ,0xFF ,0xFF ,0xFF ,0xFF ,0x00 ,0x41 ,0x0C, 0xCF ,0x08 ,0x04 ,0x00 ,0x00 ,0x00 ,0x0A ,0x17 ,0x01 ,0x03, 0x80 ,0x3C ,0x22 ,0x78 ,0x2A ,0x2C ,0xC5 ,0xA5 ,0x55 ,0x54, 0xA1 ,0x27 ,0x0C ,0x50 ,0x54 ,0xB1 ,0x08 ,0x00 ,0xD1 ,0xC0, 0xB3 ,0x00 ,0x95 ,0x00 ,0x81 ,0x80 ,0x81 ,0xC0 ,0x01 ,0x01, 0x01 ,0x01 ,0x01 ,0x01 ,0x02 ,0x3A ,0x80 ,0x18 ,0x71 ,0x38, 0x2D ,0x40 ,0x58 ,0x2C ,0x45 ,0x00 ,0x56 ,0x50 ,0x21 ,0x00, 0x00 ,0x1E ,0x00 ,0x00 ,0x00 ,0xFF ,0x00 ,0x41 ,0x55 ,0x34, 0x31 ,0x33 ,0x31 ,0x30 ,0x30 ,0x30 ,0x30 ,0x30 ,0x30 ,0x34, 0x00 ,0x00 ,0x00 ,0xFC ,0x00 ,0x50 ,0x48 ,0x4C ,0x20 ,0x43, 0x32 ,0x37 ,0x31 ,0x50 ,0x34 ,0x0A ,0x20 ,0x20 ,0x00 ,0x00, 0x00 ,0xFD ,0x00 ,0x38 ,0x47 ,0x1E ,0x53 ,0x11 ,0x00 ,0x0A, 0x20 ,0x20 ,0x20 ,0x20 ,0x20 ,0x20 ,0x01 ,0xEA } write_add_ksv(0x73,0x04);//ENable edidb write_add_hdmi(0x1,0x48);//ENable port b clock __raw_writeb(0x1,HPDCT);//ENABLE HDMI HPD write_add(0x3,0x9); write_add(0x1D,0x40); write_add1(0x9a,0xff); write_add(0x68,0xF0);//ypbpr out write_add(0x6B,0xF3); write_add(0xBA,0xA0);//Enable HDMI and Analog in write_add(0x73,0xCD);// write_add(0x74,0xC4);// write_add(0x75,0x01);// write_add(0x76,0x00);// write_add(0x7B,0x2f);//Outputs progressive timing write_add(0x81,0xD0);//Enable GR_AV_BL_EN write_add2(0xF0,0x10); write_add2(0xF1,0x0F); write_add2(0xF4,0x20); |
yweyerwq 发表于 2019-3-11 17:31 请专家帮忙分析下,谢谢~ |
你的HDMI源是什么? 从现在现象看十分可能你的HDMI源根本就没有送出信号. 你可以利用HDMI Map, 0x04[2]看看有没有clock送进来. 利用HDMI Map, 0x07[4]可以检测HDMI有没有锁住. 另外HDMI需要256的EDID, 而不是128的. |
1051 浏览 2 评论
1430 浏览 2 评论
1970 浏览 1 评论
4296 浏览 2 评论
9094 浏览 1 评论
1653浏览 3评论
1718浏览 2评论
1051浏览 2评论
1713浏览 2评论
1430浏览 2评论
GMT+8, 2025-1-14 13:22 , Processed in 0.696857 second(s), Total 49, Slave 43 queries .
