电子发烧友william hill官网
你好!
在这里,我们使用Parallel Cable III和Windows XP与基于XC95144XL的主板配合使用。 现在我们将大多数计算机升级到Windows 7 - 所以哪个版本的ISE支持旧的Parallel Cable III,我们的CPLD和Windows 7(无论是32位还是64位)? 以上来自于谷歌翻译 以下为原文 Hi there! Here we were using a Parallel Cable III and Windows XP to work with our XC95144XL based boards. Now we upgraded most of the computers to Windows 7 - so which version of ISE does support the old Parallel Cable III, our CPLD and Windows 7 (regardless of 32 or 64 bit)? |
9个回答
添加到上述语句中,Windows7 OS不支持10.1。
http://www.xilinx.com/itp/xilinx10/swcol/whatsnew.htm --Krishna 在原帖中查看解决方案 以上来自于谷歌翻译 以下为原文 adding to the above statement, 10.1 is not supported in Windows7 OS. http://www.xilinx.com/itp/xilinx10/swcol/whatsnew.htm --Krishna View solution in original post |
嗨,XC95144XL支持最新的Xilinx ISE工具。
即ISE 14.7。谢谢,Vinay -------------------------------------------------- ------------------------------------------您是否尝试在Google中输入问题? ? 如果没有,你应该在发布之前。 此外,MARK这是一个答案,以防它有助于解决您的查询/问题。给予帮助您找到解决方案的帖子。 以上来自于谷歌翻译 以下为原文 Hi, XC95144XL is supported with latest Xilinx ISE tools. i.e., ISE 14.7. Thanks, Vinay-------------------------------------------------------------------------------------------- Have you tried typing your question in Google? If not you should before posting. Also, MARK this is as an answer in case it helped resolve your query/issue.Give kudos to the post that helped you to find the solution. |
以下答案记录涉及所有与电缆相关的使用查询
http://www.xilinx.com/support/answers/54381.html http://www.xilinx.com/support/answers/20429.html _______________________________________________如果有助于解决您的查询,请将此帖子标记为“接受为解决方案”。 因此,它将有助于其他william hill官网 用户直接参考答案。如果您认为该信息有用且面向答复,请给予此帖子称赞。 以上来自于谷歌翻译 以下为原文 The below Answer records address all cable related usage queries http://www.xilinx.com/support/answers/54381.html http://www.xilinx.com/support/answers/20429.html ________________________________________________ Please mark this post as an "Accept as solution" in case if it helped to resolve your query. So that it will help to other forum users to directly refer to the answer. Give kudos to this post in case if you think the information is useful and reply oriented. |
嗨,最后支持的并行电缆3版本是ISE 10.1。请参考http://www.xilinx.com/support/documentation/user_guides/xtp029.pdf问候,Krishna
-------------------------------------------------- ---------------------------------------------请将帖子标记为 如果提供的信息能够回答您的问题/解决您的问题,请“接受为解决方案”。给予您认为有用的帖子。 以上来自于谷歌翻译 以下为原文 Hi, The last supported version of parallel cable 3 is ISE 10.1. Please refer to http://www.xilinx.com/support/documentation/user_guides/xtp029.pdf Regards, Krishna----------------------------------------------------------------------------------------------- Please mark the post as "Accept as solution" if the information provided answers your query/resolves your issue. Give Kudos to a post which you think is helpful. |
http://www.xilinx.com/itp/xilinx10/swcol/whatsnew.htm --Krishna 以上来自于谷歌翻译 以下为原文 adding to the above statement, 10.1 is not supported in Windows7 OS. http://www.xilinx.com/itp/xilinx10/swcol/whatsnew.htm --Krishna |
谢谢你的快速解答。
@umamahe:这些文章都没有提到Parallel Cable III。 以上来自于谷歌翻译 以下为原文 Thanks for your quick answers. @umamahe: Neither of these articles are mentioning the Parallel Cable III. |
@smarelland kkn:所以Parallel Cable III无法与Windows 7兼容,这是否真的正确?
以上来自于谷歌翻译 以下为原文 @smarell and kkn: So there is no way that the Parallel Cable III will work with Windows 7, is this really correct? |
老实说,大多数足以运行Windows 7的计算机都没有并行端口了。
此外,对并行电缆的旧支持并不好,并且对大多数附加并行端口适配器不起作用。 您可以尝试在Windows 7下的WinXP虚拟机中运行ISE 10.1,但此时最好的办法是获取USB电缆(或者找一台真正用作编程站的旧电脑)。 - Gabor 以上来自于谷歌翻译 以下为原文 Honestly most computers new enough to run Windows 7 don't have a parallel port anymore. In addition, the old support for the parallel cables was not good, and didn't work for most add-on parallel-port adapters. You could try to run ISE 10.1 in a WinXP virtual machine under Windows 7, but your best bet at this point is to get a USB cable (or find a really old computer to use as your programming station). -- Gabor |
我决定现在使用具有并行端口的两台旧笔记本电脑,这些笔记本电脑无法通过Windows 7对这些芯片进行编程。
这必须足够,直到我们停止这些板。 以上来自于谷歌翻译 以下为原文 I decided that we use now two old laptops with parallel ports which aren't capable of Windows 7 to program these chips. This must be enough until we discontinue these boards. |
2429 浏览 7 评论
2830 浏览 4 评论
2298 浏览 9 评论
3378 浏览 0 评论
2468 浏览 15 评论
1295浏览 1评论
592浏览 1评论
455浏览 1评论
2010浏览 0评论
736浏览 0评论
GMT+8, 2024-12-27 07:11 , Processed in 1.429653 second(s), Total 60, Slave 55 queries .
