你好,
我有一个峰,峰值幅度为0.5V,频率为25Hz。我需要测量这个信号的均方根值。如何将此信号连接到PSoC并测量信号的-VE部分。 感谢任何指针。 以上来自于百度翻译 以下为原文 Hi, I have an AC signal with a peak to peak amplitude of 0.5V and a frequency of 25Hz. I need to measure the RMS value of this signal. How do I connect this signal to the PSoC and measure the -ve part of the signal. Thanks in advance for any pointers. |
3个回答
如果您的信号接地与PSoC接地隔离,那么您可以将AGND带到PSoC的外部引脚,并将信号连接到这个AGND上。如果您的信号接地与PSoC的VSS相同,则可以使用电容器将信号连接到PSoC的输入端,并将PSoC的输入偏置到AGND。看看下面的文章,这两种方法都有更多的细节。使用PSOC1最佳测量负电压,PSoC黑客GANSIH
以上来自于百度翻译 以下为原文 If your signal ground is isolated from PSoC ground, then you can bring out the AGND to an external pin of PSoC and connect the signal with respect to this AGND. If your signal ground is same as VSS of PSoC, then the signal can be connected to the input of PSoC using a capacitor and biasing the input of PSoC to AGND. Check out the below article that has more details on both these methods. Measuring Negative Voltage Using PSoC1 Best Regards, Ganesh The PSoC Hacker |
非常感谢您的快速响应。我的信号接地不是与PSoC接地隔离的。因此,我将使用C/R方法将信号馈送到PSoC的输入端。再次感谢您指引我走向正确的方向。
以上来自于百度翻译 以下为原文 Thank you very much for the fast response. My signal ground is not isolated from the PSoC Ground. So, I will use the C/R method of feeding the signal to the input of the PSoC. Thanks again for pointing me in the right direction. |
欢迎光临!很高兴能帮上忙。
最好的问候, 加内什 PSoC Hacker 以上来自于百度翻译 以下为原文 You are most welcome!! Glad to be of help. Best Regards, Ganesh The PSoC Hacker |
754个成员聚集在这个小组
加入小组2113 浏览 1 评论
1858 浏览 1 评论
3673 浏览 1 评论
1793 浏览 6 评论
1540 浏览 1 评论
580浏览 2评论
432浏览 2评论
444浏览 2评论
391浏览 2评论
991浏览 2评论
GMT+8, 2024-12-29 23:22 , Processed in 0.542942 second(s), Total 48, Slave 42 queries .
