最快的定时器中断能实现一毫秒吗?我在运行默认时钟。系统时钟为403.2兆赫。
以上来自于百度翻译 以下为原文 Is the fastest timer interrupt I can achieve one millisecond? I'm running default clocks. System clock is 403.2 MHz. |
可以给复杂GPIO提供的最大频率是SysSLCK/2,所以它是大约200兆赫,并且说你保持一个阈值1,而配置复杂的GPIO它应该是一半的值。从理论上说,它将是100MHz,但在这种速度下,如果你触发中断,我怀疑你将能够执行任何事情。
你的应用程序的频率是多少? 当做, 阿南德 以上来自于百度翻译 以下为原文 The maximum frequency you can feed the complex GPIO is SYS_CLK/2 so it is around 200MHz and say you keep a threshold value of 1 while configuring the complex GPIO it should half the value. so theoretically it would be 100MHz but at that speed if you trigger the interrupt I doubt you'll be able to execute anything. What is the frequency you're looking at for your application? Regards, Anand |
754个成员聚集在这个小组
加入小组2110 浏览 1 评论
1858 浏览 1 评论
3673 浏览 1 评论
1791 浏览 6 评论
1540 浏览 1 评论
575浏览 2评论
428浏览 2评论
439浏览 2评论
389浏览 2评论
921浏览 2评论
GMT+8, 2024-12-26 17:24 , Processed in 0.882147 second(s), Total 76, Slave 60 queries .
