引用: lmksa 发表于 2019-4-29 14:01
Momentum是一个平面模拟器,其中电介质是无限的,因此您无法在迹线下方模拟有限的电介质宽度。
但我希望无限条带具有较低的共振频率,而不是更高,所以也许其他错误。
根据我在EM建模方面的经验,问题通常出在模型中而不是模拟工具中。
亲爱的沃尔克先生,非常感谢你跟进我的要求。
附件是我试图模拟的天线的Ring_Antenna.zap文件。
我使用ADS 2009归档了该项目,因此希望您可以将其导入到更新版本的ADS中。
我同意你的共振频率应该低一些不高。
就像一条信息一样,我使用Allegro设计天线几何,并将其导出为DXF文件。
然后我将它导入到ADS中,我想知道导入过程是否会导致它被误读或误解。
一旦您尝试将其加载到最新版本的ADS中,我一定会从您那里学到一些东西。
运行后,我是否可以将导出的项目从较高版本加载到较低版本?
无论如何我会尝试加载它,但也许你可以告诉我你在项目中看错了什么。
最好的问候,谢谢你的帮助rjrodrig
以上来自于谷歌翻译
以下为原文
Dear Mr. Volker,
Thank you so much for following up on my request. Attached is the Ring_Antenna.zap file for the antenna I am trying to simulate. I archived the project using ADS 2009 so hopefully you can import it into a more recent version of ADS. I do agree with you the resonant frequency should be lower not higher. Just as a piece of information, I used Allegro to design the antenna geometry, and exported it as a DXF file. I then imported it into ADS, and I wonder if the import process caused it to be misread or misinterpreted in anyway.
I will certainly learn something from you once you attempt to load it into your most recent version of ADS. After you run it, will I be able to load your exported project from a higher version to a lower version? I will try to load it anyway, but maybe you might be able to tell me what you see wrong on the project.
Best regards, and thank you for your help
rjrodrig
附件
我同意你的共振频率应该低一些不高。
以上来自于谷歌翻译
以下为原文
Dear Mr. Volker,
rjrodrig
附件
