电子发烧友william hill官网
嗨!
我正在尝试使用xapp495 HDMI演示......我使用的是Atlys斯巴达6板。 但我不能让它发挥作用..如果有任何人有这个核心的经验,请回复。 我真的很感激我能得到的任何帮助。 谢谢。 以上来自于谷歌翻译 以下为原文 Hi! I am trying to use the xapp495 HDMI demo... I am using a Atlys spartan 6 board. But i coud not get it to work.. If there is anyone who has experience with this core, plese reply. I realy appreciate any help i can get. Thanks. |
您是否有机会访问以下相关william hill官网
帖子。
他们可以为您的调试提供帮助或提供有用的提示 http://forums.xilinx.com/xlnx/board/crawl_message?board.id=OTHERBRD&message.id=541 http://forums.xilinx.com/xlnx/board/crawl_message?board.id=OTHERBRD&message.id=515 http://forums.xilinx.com/xlnx/board/crawl_message?board.id=NewUser&message.id=4111 http://forums.xilinx.com/xlnx/board/crawl_message?board.id=Spartan&message.id=21280 另请参阅http://www.xilinx.com/publications/prod_mktg/S6CVK2.0_ProductFAQ.pdf _______________________________________________如果有助于解决您的查询,请将此帖子标记为“接受为解决方案”。 因此,它将有助于其他william hill官网 用户直接参考答案。如果您认为该信息有用且面向答复,请给予此帖子称赞。 以上来自于谷歌翻译 以下为原文 Did you get chance to below related forums posts. They may help or gives useful tips for your debugging http://forums.xilinx.com/xlnx/board/crawl_message?board.id=OTHERBRD&message.id=541 http://forums.xilinx.com/xlnx/board/crawl_message?board.id=OTHERBRD&message.id=515 http://forums.xilinx.com/xlnx/board/crawl_message?board.id=NewUser&message.id=4111 http://forums.xilinx.com/xlnx/board/crawl_message?board.id=Spartan&message.id=21280 Also refer http://www.xilinx.com/publications/prod_mktg/S6CVK2.0_ProductFAQ.pdf ________________________________________________ Please mark this post as an "Accept as solution" in case if it helped to resolve your query. So that it will help to other forum users to directly refer to the answer. Give kudos to this post in case if you think the information is useful and reply oriented. |
2431 浏览 7 评论
2831 浏览 4 评论
2300 浏览 9 评论
3379 浏览 0 评论
2468 浏览 15 评论
1394浏览 1评论
597浏览 1评论
462浏览 1评论
2015浏览 0评论
739浏览 0评论
GMT+8, 2024-12-29 23:56 , Processed in 1.106875 second(s), Total 47, Slave 41 queries .
