大家好,
我找不到内部温度传感器的相对引脚。有谁知道它是哪个引脚?或者我应该只配置ADC_TRIGR1寄存器中的TSON位来唤醒温度传感器? 事实上,当我想在adc上选择正确的频道时,问题也会出现。有人可以帮忙吗? 非常感谢, 最好, 吉尔伯托 #stm8l152c6t6温度传感器 以上来自于谷歌翻译 以下为原文 Hello everyone, I can't find the relative pin to the internal temperature sensor. Does anyone know which pin is it? Or should i only configure the TSON bit in the ADC_TRIGR1 register to wake up the temperature sensor? In fact the problem rises also when i want to select the right channel on the adc.. Can anyone help please? thanks a lot, best, Gilberto #stm8l152c6t6-temperature-sensor |
你好Gilberto!
没有微控制器引脚连接到内部温度传感器。 如果要使用它,则必须通过将ADC_TRIG1中的TSON位置1来将其打开。 当唤醒时间结束时(参见数据表),可以通过将ADC_SQR1中的CHSEL_STS位置1并开始采集来读取内部温度传感器值。 请注意,必须校准每个温度传感器。 请参阅AN3397“使用STM8L-DISCOVERY板的温度传感器示例”。 问候, EtaPhi 以上来自于谷歌翻译 以下为原文 Hello Gilberto! No micro-controller pin is connected to the internal temperature sensor. If you want to use it, you have to switch it on by setting the TSON bit in ADC_TRIG1. When its wake-up time is elapsed (see the datasheet), the internal temperature sensor value can be read by setting the CHSEL_STS bit in ADC_SQR1 and by starting an acquisition. Please, be informed that each temperature sensor must be calibrated. See AN3397 ''Temperature sensor example using the STM8L-DISCOVERY board''. Regards, EtaPhi |
2790 浏览 1 评论
3254 浏览 1 评论
1827 浏览 1 评论
3672 浏览 6 评论
6069 浏览 21 评论
1352浏览 4评论
对H747I-DISCO写程序时将CN2的st-link复用为usart1,再次烧录时无法检测到stlink怎么解决?
374浏览 2评论
STM32G474RE芯片只是串口发个数据就发烫严重是怎么回事?
471浏览 2评论
STM32处理增量式编码器Z信号如何判断中断是正转的还是反向转的?
294浏览 2评论
使用STM32F407VET6的USB2.0功能,发现ctl后芯片无数据返回,是什么原因可能导致的呢?
218浏览 2评论
GMT+8, 2025-1-15 05:07 , Processed in 1.062929 second(s), Total 75, Slave 59 queries .
