嗨,伙计们。我想用ADC在单采样模式下(由硬件SoC输入触发),并通过从ADC捕获中断获得转换后的数据。
数据表告诉我在ADCJ-Delsig中存在内部中断,但是我不能用下面的代码获得任何转换结果。 如有任何帮助,我们将不胜感激。 ---------------------------- 包括: 包括: UIT16结果=0; UIT8 8 DATAARDY=0; CysISR(ADCX-SARYA 1AISR) { 结果= ADCJ-DELSIGLY1GETRESULT16L(); 结果=AdcDeligy11CurtStokes Mvots(结果); DATAARADY=1U; } 空主程序() { 囊状的; LCDA CHARY1LSTATE(); AdcDeligy11StiX(); AdcDeligy1IrqqnEnable(); (;) { 如果(DATARADY!= 0){ DATaRADY=0; LCD-CHAR1L1位(1,0); LCDA CHARY1LIN号(结果); } } } 以上来自于百度翻译 以下为原文 Hi Guys. I want to use ADC at single sampling mode(triggered by hardware soc input) and get the converted data by catching interrupt from ADC. The datasheet tells me internal interrupt exists in ADC_DelSig, but I cannot get any converted result with the code as below. Any help will be appreciated. ------------------------------------ #include #include uint16 result=0; uint8 dataready=0; CY_ISR(ADC_SAR_1_ISR) { result = ADC_DelSig_1_GetResult16(); result = ADC_DelSig_1_CountsTo_mVolts(result); dataready = 1u; } void main() { CyGlobalIntEnable; LCD_Char_1_Start(); ADC_DelSig_1_Start(); ADC_DelSig_1_IRQ_Enable(); for(;;) { if(dataready!=0){ dataready=0; LCD_Char_1_Position(1,0); LCD_Char_1_PrintNumber(result); } } } |
6个回答
……并且另外:
CYI ISRL PROTO(YouHand); . . CysISR(YouHuffer-Lead) { /把你的代码放在这里 } ISRY11SARTTEX(YouHuffer-Lead);/初始化和启动中断处理 这个名字是正确的吗? 鲍勃 以上来自于百度翻译 以下为原文 ...and additionally: CY_ISR_PROTO(YourHandler); . . CY_ISR(YourHandler) { // Place your code here } isr_1_StartEx(YourHandler); // Initialize and start interrupt handling CyGlobalIntEnable; // Is that the correct name? Bob |
根据ADCJ-Delsig V2.30数据表,它表示(第3页底部)
“PSoC 5的EOC在如何连接方面受到限制。除了单个DMA组件之外,EOC终端是不可路由的。 因此,我认为将中断组件直接连接到EOC输出不是一个选项,因为我使用PSoC5板。 以上来自于百度翻译 以下为原文 According to the ADC_DelSig v2.30 datasheet, it says(bottom of page 3) "The EOC for PSoC 5 is restricted in how it can be connected. The EOC terminal is not routable except to a single DMA component." So, I think connect an interrupt component directly to eoc output is not a option since I'm using PSoC5 board. |
我还有一个问题。转换后的单采样模式ADCJ-Delsig的EOC输出变高吗?
数据表说,ADC只是在单模式转换后“停止”。 以上来自于百度翻译 以下为原文 I have another question. Does single sampling mode ADC_DelSig's eoc output becomes HIGH after its conversion? The datasheet says that ADC just 'halts' after conversion at single mode. |
奇数,在PSoC 5 TRM中讨论EOC,而不在5LP TRM中。
问候,Dana。 以上来自于百度翻译 以下为原文 Odd, in PSOC 5 TRM a discussion of EOC is present, buit not in the 5LP TRM. Regards, Dana. |
谢谢你的回复:
他们对我帮助很大。 以上来自于百度翻译 以下为原文 Thank you for your replies :). They were a lot of help to me. |
756个成员聚集在这个小组
加入小组2125 浏览 1 评论
1867 浏览 1 评论
3683 浏览 1 评论
1803 浏览 6 评论
1551 浏览 1 评论
613浏览 2评论
456浏览 2评论
451浏览 2评论
403浏览 2评论
1090浏览 2评论
GMT+8, 2025-1-15 21:39 , Processed in 0.940270 second(s), Total 85, Slave 69 queries .
