嗨,
我使用promgen命令两次生成我的多重引导文件,一次用于标题,第二次用于黄金和多重引导(参见下面的命令)。 我觉得找到最终mcs文件(Main_multiboot.mcs)的正确舞会校验和的唯一方法是使用Impact应用程序并将其下载到Flash。 有没有其他方法可以更快地为Main_multiboot.mcs(使用promgen)获得总的舞会校验和? promgen -w -p mcs -r multiboot_header.hex -o multiboot_header.mcspromgen -w -c -p mcs -spi -s 2048 -u 010000 golden.bit -u 100000 Main.bit -o incomplete_dual_image.mcstype multiboot_header.mcs incomplete_dual_image。 mcs> Main_Multiboot.mcs谢谢。 以上来自于谷歌翻译 以下为原文 Hi, I use the promgen command twice to generate my multiboot file, once for the header and second for golden and multiboot (see the commands below). I blive the only way to get find out the correct prom checksum for the final mcs file (Main_multiboot.mcs) is to use the Impact application and download it to the Flash. Is there any other way to get the total prom checksum faster for the Main_multiboot.mcs (using promgen)? promgen -w -p mcs -r multiboot_header.hex -o multiboot_header.mcs promgen -w -c -p mcs -spi -s 2048 -u 010000 golden.bit -u 100000 Main.bit -o incomplete_dual_image.mcs type multiboot_header.mcs incomplete_dual_image.mcs > Main_Multiboot.mcs Thanks. |
请按照http://www.xilinx.com/support/documentation/sw_manuals/xilinx14_3/devref.pdf中的信息进行操作。
_______________________________________________如果有助于解决您的查询,请将此帖子标记为“接受为解决方案”。 因此,它将有助于其他william hill官网 用户直接参考答案。如果您认为该信息有用且面向答复,请给予此帖子称赞。 以上来自于谷歌翻译 以下为原文 Please follow the information in http://www.xilinx.com/support/documentation/sw_manuals/xilinx14_3/devref.pdf ________________________________________________ Please mark this post as an "Accept as solution" in case if it helped to resolve your query. So that it will help to other forum users to directly refer to the answer. Give kudos to this post in case if you think the information is useful and reply oriented. |
2448 浏览 7 评论
2846 浏览 4 评论
2310 浏览 9 评论
3391 浏览 0 评论
2486 浏览 15 评论
1775浏览 1评论
623浏览 1评论
485浏览 1评论
2036浏览 0评论
762浏览 0评论
GMT+8, 2025-1-13 11:06 , Processed in 1.490542 second(s), Total 76, Slave 60 queries .
