您好,我的HP 8114A的仪器控制有一个小问题。
我的愿望是:1 - 发送命令改变发电机2的电压 - 检查命令是否已正确执行。 如果没有,那么我应该等到命令完成。 对于第一部分,我已经用以下SCIPI命令弄明白了:* SOUR:VOLT 80V *对于第二部分,我认为解决方案是:** OPC?*我的问题是执行最后一个命令和读出 时间很长(我会说约500毫秒)。 有更快的方法吗? 以上来自于谷歌翻译 以下为原文 Hello, I have a small matter with the instrument control of my HP 8114A. My wish is to : 1 - send a command to change the voltage of the generator 2 - check if the command has been properly executed. If not then I should wait until the command is done. For the first part, I allready figure it out with the following SCIPI command : *SOUR:VOLT 80V* For the second part I think a solution is : **OPC?* My problem is that the execution of the last command and the readout time is long (around 500ms I would say). Is there a quicker way to do it ? |
3个回答
嗨Pierre447,我看了一下手册,看起来HP 8114A支持“SYST:ERR?”
查询。 您可以在每次查询后使用此命令检查是否存在任何仪器错误。 *应在触发情况下使用OPC(操作完成),以了解仪器何时准备好读回测量数据。 连接 以上来自于谷歌翻译 以下为原文 Hi Pierre447, I took a look at the manual and it looks like the HP 8114A supports the "SYST:ERR?" query. You can use this command after each query to check for any instrument errors. *OPC (Operation Complete) should be used in trigger situations to know when the instrument is ready to read back measurement data. connectivity |
schumi_LYQ 发表于 2019-7-18 10:24 你好连接,谢谢你的回答,我理解你的建议。 我想我之前没有正确解释我的问题......我实际上处于触发状态 - 正如你所建议我想知道仪器什么时候准备回读测量数据。 我的问题是命令* OPC需要花费大量时间来执行 - 大约400ms ......我需要减少这个执行时间 - 到20 ms是完美的。 手动说明一般情况下,命令执行时间应该在5到20毫秒左右,所以我不明白为什么这应该是一个问题......我想知道为什么这个特定的* OPC命令花了这么多时间来执行.. 。您是否知道一个命令能够以比* OPC命令更短的执行时间检查仪器的准备状态? 无论如何,感谢您花时间考虑我的问题,这真的很有帮助! 此致,Pierre447 以上来自于谷歌翻译 以下为原文 Hello connectivity and thanks for your answer, I understand your suggestion. I think I did not properly explained my problem before... I am actually in a trigger situation - as you suggested I want to know when the instrument is ready to read back measurement data. My problem is that the command *OPC is taking a lot of time to execute - about 400ms... I need to reduce this execution time - to 20 ms would be perfect. The manual state that in general case, command execution time should be around 5 to 20 ms so I don't see why this should be a problem... I wonder why this specific *OPC command is taking so much time to execute... Do you have any knowledge of a command that would perform a check of the readyness of the instrument with a smaller execution time than the *OPC command ? Anyway, thanks for taking the time to consider my problem, it really help ! Regards, Pierre447 |
wo97306730 发表于 2019-7-18 10:33 任何人 ? 以上来自于谷歌翻译 以下为原文 Anyone ? |
1317 浏览 0 评论
2389 浏览 1 评论
2207 浏览 1 评论
2079 浏览 5 评论
2963 浏览 3 评论
1196浏览 1评论
770浏览 0评论
994浏览 0评论
1317浏览 0评论
GMT+8, 2025-1-7 05:57 , Processed in 1.238621 second(s), Total 82, Slave 66 queries .
