你好,
我有一个最初使用Spartan 3A入门套件开发板实现的应用程序。 我有FPGA的位文件,一切都按设计正常运行。 最近我们需要构建更多的应用程序,但是我们无法购买原始的Spartan 3A套件(不再有库存),而是购买了Spartan 3AN套件。 我知道通过重新运行原始源代码并将目标设备从Spartan 3A更改为Spartan 3AN,我可以获得适合Spartan 3AN的位文件。 但有没有一种更简单的方法可以将原始的3A位文件直接转换为3AN设备,而无需重新运行整个实现流程? 谢谢, 德里克刘易斯 以上来自于谷歌翻译 以下为原文 Hello, I have an application that was originally implemented using a Spartan 3A Starter Kit development board. I have the bit files for the FPGA and everything has been operating correctly as designed. Recently we needed to build some more of the applications, but we were unable to buy the original Spartan 3A kits (not in stock anymore), but got Spartan 3AN kits instead. I know that by rerunning the original source code and changing the target device from Spartan 3A to Spartan 3AN, I can get the bitfile suitable for Spartan 3AN. But is there an easier method which can translate the original 3A bitfile directly to the 3AN device, without rerunning the entire implementation flow ? Thanks, Derric Lewis |
5个回答
你应该可以使用它。
-------------------------------------------------- ---------------------------------------------请将帖子标记为 如果提供的信息能够回答您的问题/解决您的问题,请“接受为解决方案”。给予您认为有用的帖子。 在原帖中查看解决方案 以上来自于谷歌翻译 以下为原文 You should be able to use it.----------------------------------------------------------------------------------------------- Please mark the post as "Accept as solution" if the information provided answers your query/resolves your issue. Give Kudos to a post which you think is helpful.View solution in original post |
不支持此类功能。
您需要使用新的目标板重新实现设计。 谢谢和RegardsBalkrishan ----------------------------------------------- ---------------------------------------------请将帖子标记为 一个答案“接受为解决方案”,以防它有助于解决您的查询。如果一个帖子引导到解决方案,请给予赞誉。 以上来自于谷歌翻译 以下为原文 No such feature is not supported . You need to re implement the design with new target board.Thanks and Regards Balkrishan -------------------------------------------------------------------------------------------- Please mark the post as an answer "Accept as solution" in case it helped resolve your query. Give kudos in case a post in case it guided to the solution. |
设备尺寸是否相同?
3S200a对比3S200AN? 如果是这样,那么如果你没有使用现在是SPI prom内部的引脚,那么bitfile应该按原样工作。 ------您是否尝试在Google中输入问题? 如果没有,你应该在发布之前。太多结果? 尝试添加网站:www.xilinx.com 以上来自于谷歌翻译 以下为原文 Is the device size identical? 3S200a vs 3S200AN? If so then the bitfile should work as-is if you aren't using pins that are now internal for the SPI prom.------Have you tried typing your question into Google? If not you should before posting. Too many results? Try adding site:www.xilinx.com |
是的,设备尺寸相同,包装也相同。
具体来说,原始设备是xc3s700a-4fg484,新设备是xc3s700an-4fgg484。 谢谢, 以上来自于谷歌翻译 以下为原文 Yes the device size is identical and the package is also identical. Specifically, the original device is xc3s700a-4fg484 and the new one is xc3s700an-4fgg484. Thanks, |
我使用XC3S700A设备为XC3S700A设备生成的位文件和XC3S700AN设备,系统按原设计正常工作。
谢谢你的帮助,祝你好运, 德里克刘易斯 以上来自于谷歌翻译 以下为原文 I used the bit file generated for the XC3S700A device on the board with the XC3S700AN device, and the system works correctly as originally designed. Thanks for the assistance, Best regards, Derric Lewis |
2429 浏览 7 评论
2831 浏览 4 评论
2298 浏览 9 评论
3378 浏览 0 评论
2468 浏览 15 评论
1347浏览 1评论
596浏览 1评论
460浏览 1评论
2013浏览 0评论
738浏览 0评论
GMT+8, 2024-12-28 20:27 , Processed in 1.433986 second(s), Total 84, Slave 68 queries .
