电子发烧友william hill官网
PingFang SC", Helvetica, Arial, "Hiragino Sans GB", "Microsoft YaHei", SimSun, 宋体, Heiti, 黑体, sans-serif;'>然后执行下面的命令:~ $ sudo /etc/init.d/dphys-swapfile stopPingFang SC", Helvetica, Arial, "Hiragino Sans GB", "Microsoft YaHei", SimSun, 宋体, Heiti, 黑体, sans-serif;'>安装依赖
~ $ sudo apt-get build-dep qt4-x11~ $ sudo apt-get build-dep libqt5gui5PingFang SC", Helvetica, Arial, "Hiragino Sans GB", "Microsoft YaHei", SimSun, 宋体, Heiti, 黑体, sans-serif;'>新建文件夹用来编译(影子编译) ~ $ mkdir buildLiberation Mono", Menlo, Courier, monospace, sans-serif; margin: 0px; border-radius: 3px; word-break: normal; border: 0px; line-height: inherit; overflow-wrap: normal;'>~ $ git clone https://github.com/oniongarlic/qt-raspberrypi-configuration.gitPingFang SC", Helvetica, Arial, "Hiragino Sans GB", "Microsoft YaHei", SimSun, 宋体, Heiti, 黑体, sans-serif;'>配置编译选项 build $ PKG_CONFIG_LIBDIR=/usr/lib/arm-linux-gnueabihf/pkgconfig:/usr/share/pkgconfig ../qt-everywhere-src-5.14.2/configure -platform linux-rpi4-v3d-g++ -D__ARM_ARCH_5TEJ__ -v -opengl es2 -eglfs -no-gtk -opensource -confirm-license -release -reduce-exports -force-pkg-config -nomake examples -no-compile-examples -skip qtwayland -skip qtwebengine -no-feature-geoservices_mapboxgl -qt-pcre -no-pch -ssl -evdev -system-freetype -fontconfig -glib -prefix /opt/Qt5.14 -qpa eglfs PingFang SC", Helvetica, Arial, "Hiragino Sans GB", "Microsoft YaHei", SimSun, 宋体, Heiti, 黑体, sans-serif;'>不过先不要着急,我在实际测试的时候还需要单独编译三个模块,不然后面安装会报错build $ cd qtlocation/src/3rdparty/clip2triclip2tri $ sudo make clip2tri $ cd qtlocation/src/3rdparty/clipperclipper $ sudo make clipper $ cd qtlocation/src/3rdparty/poly2tripoly2tri $ sudo makePingFang SC", Helvetica, Arial, "Hiragino Sans GB", "Microsoft YaHei", SimSun, 宋体, Heiti, 黑体, sans-serif;'>如果没有错误的话就应该可以看见跟下面一样的输出了:QMake version 3.1PingFang SC", Helvetica, Arial, "Hiragino Sans GB", "Microsoft YaHei", SimSun, 宋体, Heiti, 黑体, sans-serif;'>将下面两行代码保存到文件中:/opt/Qt5.14/binPingFang SC", Helvetica, Arial, "Hiragino Sans GB", "Microsoft YaHei", SimSun, 宋体, Heiti, 黑体, sans-serif;'>新建文件夹用来编译(影子编译) ~ $ mkdir qtcreator-buildPingFang SC", Helvetica, Arial, "Hiragino Sans GB", "Microsoft YaHei", SimSun, 宋体, Heiti, 黑体, sans-serif;'>编译倒是没那么复杂,不过也是一个非常耗时的过程,大约得五六个小时左右... 依次执行下面的命令即可:qtcreator-build $ qmake -r ../qt-creator-opensource-src-4.12.0PingFang SC", Helvetica, Arial, "Hiragino Sans GB", "Microsoft YaHei", SimSun, 宋体, Heiti, 黑体, sans-serif;'>恭喜你,到这里你已经成功将开发环境搭建好了!!! |
813 浏览 0 评论
1162 浏览 1 评论
2535 浏览 5 评论
2871 浏览 9 评论
2719 浏览 6 评论
1109浏览 3评论
198浏览 2评论
465浏览 2评论
379浏览 2评论
461浏览 1评论
GMT+8, 2024-12-27 12:21 , Processed in 0.986677 second(s), Total 78, Slave 59 queries .
