单片机学习小组
登录
风来吴山
8年用户
1429经验值
擅长:电源/新能源
私信
关注
CC2530具有哪几种功耗模式?它们之间有什么区别?
开启该帖子的消息推送
单片机
荣徽
2022-1-25 10:50:59
摘要
本文章主要讲述了CC2530的五种功耗模式,详细介绍了这五种功耗模式的区别,以及每种功耗模式的唤醒方法。最后通过代码,演示了这五种功耗模式(主动模式,空闲模式。PM1,PM2,PM3)之间的切换。
完整的程序源代码
#include
//定义控制灯的端口
#define LED1 P1_0 //定义LED1为P1_0口控制
#define LED2 P1_5 //定义LED2为P1_5口控制
#define LED3 P1_3 //定义LED3为P1_3口控制
#define LED4 P1_4 //定义LED4为P1_4口控制
#define SW1 P1_2 //定义SW1为P1_2端口
#define SW2 P0_1 //定义SW2为P0_1端口
//延时
char pause = 0;
void Delay_mS(unsigned int n)
unsigned int tt,i = 0;
for(i = 0; i < n; i ++)
for(tt = 0; tt<1040; tt++);
while(pause);
void Delay_2uS(unsigned int n)
unsigned int i = 0;
for(;i < n; i++);
//初始化函数
void Initial(void)
P1DIR = 0xFB;//将P12设为输入,其他设为输出 (0xFB = 11111011)
LED1 = 0;//关闭LED1
LED2 = 0;//关闭LED2
LED3 = 1;//关闭LED3
LED4 = 0;//关闭LED4
P0SEL = 0x0C; //大开P0.2,P0.3的外设功能
CLKCONCMD &= 0x80;
U0BAUD = 216; //设置波特率115200
U0GCR = 11;
U0CSR = 0xC0; //选择UART功能,并使能接收功能
URX0IE = 1; //使能UART0 接收中断
IEN2 = 0x10; //使能P1口中断
P1IEN = 0x04; //使能P1_2口中断
PICTL = 0x03; //P1_3到P1_0口下降沿触发中断
ST2 = 0; //初始化睡眠定时器中断
ST1 = 0x0F;
ST0 = 0x0F;
STIE = 1;
STIF = 0;
EA =1; // 使能总中断
//通郭串口发送字符串
void Uart_Send_Str(char * p)
while(*p != 0)
U0DBUF = *p;
p++;
while(UTX0IF == 0);
UTX0IF = 0;
//退出低功耗模式,进入主动模式
void Exit_Pm()
PCON = 0;
//进入空闲模式
void Enter_IDEL()
SLEEPCMD &= ~0x03;
PCON |= 0x01;
//进入PM1模式
void Enter_PM1()
SLEEPCMD &= ~0x03;
SLEEPCMD |= 0x01;
PCON |= 0x01;
//进入PM2模式
void Enter_PM2()
SLEEPCMD &= ~0x03;
SLEEPCMD |= 0x02;
PCON |= 0x01;
//进入PM3模式
void Enter_PM3()
SLEEPCMD &= ~0x03;
SLEEPCMD |= 0x03;
PCON |= 0x01;
//设置睡眠定时唤醒时间
void Set_ST_Time(unsigned short time)
unsigned long sleepTime = 0;
sleepTime |= ST0;
sleepTime |= (unsigned long)ST1 << 8;
sleepTime |= (unsigned long)ST2 << 16;
sleepTime += (unsigned long)time * (unsigned long)32768;
ST2 = (unsigned char )(sleepTime >> 16);
ST1 = (unsigned char )(sleepTime >> 8);
ST0 = (unsigned char )(sleepTime);
//主函数
void main(void)
Initial(); //调用初始化函数
while(1)
Delay_mS(100);//等待系统时钟稳定
Uart_Send_Str("Hello World!rn");
Uart_Send_Str("Enter IDEL Mode ... rn");
Enter_IDEL();
Uart_Send_Str("Enter PM1 Mode ... rn");
Set_ST_Time(5);
Enter_PM1();
Uart_Send_Str("Enter PM2 Mode ... rn");
Set_ST_Time(5);
Enter_PM2();
Uart_Send_Str("Enter PM3 Mode ... rn");
Enter_PM3();
Uart_Send_Str("Wake Up From PM3 ! rn");
#pragma vector = P1INT_VECTOR
__interrupt void P1_INT(void)
if (P1IFG & 0x04) //如果P1_2口中断标志位置位
Exit_Pm();//退出低功耗模式,进入主动模式
P1IFG &= ~0x04; //清除P1_2口中断标志位
P1IF=0; //清除P1口中断标志位
#pragma vector = URX0_VECTOR
__interrupt void URX0_INT(void)
if(U0DBUF == 'a')
#pragma vector = ST_VECTOR
__interrupt void ST_INT(void)
STIF = 0;
Exit_Pm();
摘要
完整的程序源代码
#include
//定义控制灯的端口
//延时
char pause = 0;
while(pause);
unsigned int i = 0;
for(;i < n; i++);
//初始化函数
void Initial(void)
LED1 = 0;//关闭LED1
LED2 = 0;//关闭LED2
LED3 = 1;//关闭LED3
LED4 = 0;//关闭LED4
CLKCONCMD &= 0x80;
U0GCR = 11;
ST1 = 0x0F;
ST0 = 0x0F;
STIE = 1;
STIF = 0;
EA =1; // 使能总中断
//通郭串口发送字符串
while(*p != 0)
U0DBUF = *p;
p++;
while(UTX0IF == 0);
UTX0IF = 0;
//退出低功耗模式,进入主动模式
void Exit_Pm()
PCON = 0;
//进入空闲模式
void Enter_IDEL()
SLEEPCMD &= ~0x03;
PCON |= 0x01;
//进入PM1模式
void Enter_PM1()
SLEEPCMD &= ~0x03;
SLEEPCMD |= 0x01;
PCON |= 0x01;
//进入PM2模式
void Enter_PM2()
SLEEPCMD &= ~0x03;
SLEEPCMD |= 0x02;
PCON |= 0x01;
//进入PM3模式
void Enter_PM3()
SLEEPCMD &= ~0x03;
SLEEPCMD |= 0x03;
PCON |= 0x01;
//设置睡眠定时唤醒时间
sleepTime |= ST0;
//主函数
void main(void)
while(1)
Enter_IDEL();
Set_ST_Time(5);
Enter_PM1();
Set_ST_Time(5);
Enter_PM2();
Enter_PM3();
if(U0DBUF == 'a')
STIF = 0;
Exit_Pm();
rotate(-90deg);
回复
相关问答
单片机
MSP430
具有
哪几种
低
功耗
模式
2022-02-15
1616
CC2530
与
CC
2520的
区别
2018-05-14
6598
STM32
具有
哪几种
待机
模式
? 待机唤醒配置步骤是怎样的?
2021-11-18
818
stm32
几种
低
功耗
模式
之间
有
什么区别
2021-11-23
666
AD9854
具有
什么特点?
有
哪几种
可编程的工作
模式
2021-04-20
1725
STM32低
功耗
模式
有
哪几种
2021-09-27
913
请问STM32低
功耗
模式
有
哪几种
2021-11-23
883
电机
具有
哪几种
控制方法?
它们
之间
的
区别
是什么?
2021-10-13
6679
HAL库的GPIO
具有
哪几种
工作
模式
2022-02-08
1126
投影显示技术
有
哪几种
它们
有
什么区别
2021-05-31
1388
登录/注册
20万+
工程师都在用,
免费
PCB检查工具
无需安装、支持浏览器和手机在线查看、实时共享
查看
点击登录
登录更多精彩功能!
英国威廉希尔公司网站
william hill官网 版块
小组
免费开发板试用
ebook
直播
搜索
登录
