本文将以Ubuntu16.04版本搭建瑞芯微RK3288开发环境
1.安装所需要的库和文件 sudo apt-get install lzop sudo apt install g++-multilib sudo apt install gperf sudo apt install libxml2-utils sudo apt install curl sudo apt-get install libc6:i386 libncurses5:i386 libstdc++6:i386 sudo apt-get install m4 sudo apt install openjdk-8-jdk openjdk-8-jre git flex bison gperf build-essential libncurses5-dev:i386 git flex bison gperf build-essential libncurses5-dev:i386 libx11- dev:i386 libreadline6-dev:i386 libgl1-mesa-dev g++-multilib tofrodos python-markdown libxml2-utils xsltproc zlib1g-dev:i386 dpkg-dev libsdl1.2-dev libesd0-dev git-core gnupg flex bison gperf build-essential zip curl zlib1g-dev gcc-multilib g++-multilib libc6-dev- i386 lib32ncurses5-dev x11proto-core-dev libx11-dev lib32z-dev ccache libgl1-mesa-dev libxml2-utils xsltproc unzip m4 sudo apt-get install git gnupg flex bison gperf libsdl1.2-dev libesd-java libwxgtk3.0-dev squashfs-tools build-essential zip curl libncurses5-dev zlib1g-dev pngcrush schedtool libxml2 libxml2-utils xsltproc lzop libc6-dev schedtool g++-multilib lib32z1-dev lib32ncurses5-dev lib32readline-dev gcc-multilib libswitch-perl libssl-dev unzip zip device-tree-compiler liblz4-tool python-pyelftools python3-pyelftools -y 2.安装所需要的软件 安装vim sudo apt install vim 安装git sudo apt install git 3.安装GCC编译器 sudo apt-get install gcc-multilib 4.安装和配置open-jdk sudo apt-get install openjdk-8-jdk sudo vim /etc/profile export JAVA_HOME=/usr/lib/jvm/java-8-openjdk-amd64 /*这个是你jdk的路径*/ export PATH=$JAVA_HOME/bin:$PATH export CLASSPATH=.:$JAVA_HOME/lib:$JAVA_HOME/lib/tools.jar 5.重启Ubuntu就已经搭建好了 |
基于米尔瑞芯微RK3576核心板/开发板的人脸疲劳检测应用方案
1743 浏览 0 评论
1830 浏览 1 评论
1508 浏览 1 评论
2852 浏览 1 评论
3906 浏览 1 评论
GMT+8, 2025-1-7 08:33 , Processed in 0.678171 second(s), Total 72, Slave 56 queries .
