1、在调试 rk3288 android 7.1 遇到部分机器不能开机的问题 logo 如下: init: Waiting for /dev/.coldboot_done... [ 3.024810] init: Waiting for /dev/.coldboot_done took 0.00s. [ 3.024848] init: /dev/hw_random not found [ 3.025097] keychord: using input dev rk29-keypad for fevent [ 3.035910] init: write_file: Unable to open '/proc/sys/abi/swp': No such file or directory [ 3.036094] init: write_file: Unable to open '/sys/module/rockchip_pm/parameters/policy': No such file or directory [ 3.036498] fs_mgr: Warning: unknown flag resize [ 3.036620] init: /dev/hw_random not found [ 3.036715] init: write_file: Unable to open '/sys/block/mmcblk0/bdi/read_ahead_kb': No such file or directory [ 3.037215] fs_mgr: Warning: unknown flag resize [ 3.217970] mmcblk2: error -110 sending stop command, original cmd response 0x900, card status 0x400900 [ 3.217986] mmcblk2: error -110 transferring data, sector 746528, nr 8, cmd response 0x900, card status 0x900 [ 3.217997] mmcblk2: retrying using single block read [ 3.218159] mmcblk2: retrying because a re-tune was needed [ 3.224562] dwmmc_rockchip ff0f0000.dwmmc: All phases work, using default phase 0. [ 3.225265] mmcblk2: retrying because a re-tune was needed [ 3.231736] dwmmc_rockchip ff0f0000.dwmmc: All phases work, using default phase 0. [ 3.231845] mmcblk2: error -84 transferring data, sector 746536, nr 8, cmd response 0x900, card status 0xb00 [ 3.231890] mmcblk2: retrying using single block read [ 3.238314] dwmmc_rockchip ff0f0000.dwmmc: All phases work, using default phase 0. [ 3.238415] mmcblk2: error -84 transferring data, sector 746536, nr 8, cmd response 0x900, card status 0x0 [ 3.238457] blk_update_request: I/O error, dev mmcblk2, sector 746536 [ 3.244867] dwmmc_rockchip ff0f0000.dwmmc: All phases work, using default phase 0. [ 3.245073] mmcblk2: error -84 transferring data, sector 746538, nr 6, cmd response 0x900, card status 0x0 [ 3.245117] blk_update_request: I/O error, dev mmcblk2, sector 746538 [ 3.251521] dwmmc_rockchip ff0f0000.dwmmc: All phases work, using default phase 0. [ 3.251728] mmcblk2: error -84 transferring data, sector 746540, nr 4, cmd response 0x900, card status 0x0 [ 3.251773] blk_update_request: I/O error, dev mmcblk2, sector 746540 [ 3.258175] dwmmc_rockchip ff0f0000.dwmmc: All phases work, using default phase 0. [ 3.258389] mmcblk2: error -84 transferring data, sector 746542, nr 2, cmd response 0x900, card status 0x0 [ 3.258435] blk_update_request: I/O error, dev mmcblk2, sector 746542 [ 3.264857] dwmmc_rockchip ff0f0000.dwmmc: All phases work, using default phase 0. [ 3.265044] mmcblk2: retrying because a re-tune was needed [ 3.268952] random: nonblocking pool is initialized [ 3.271560] dwmmc_rockchip ff0f0000.dwmmc: All phases work, using default phase 0. [ 3.271679] mmcblk2: error -84 transferring data, sector 746544, nr 240, cmd response 0x900, card status 0xb00 [ 3.271720] mmcblk2: retrying using single block read [ 3.278149] dwmmc_rockchip ff0f0000.dwmmc: All phases work, using default phase 0. [ 3.278252] mmcblk2: error -84 transferring data, sector 746544, nr 240, cmd response 0x900, card status 0x0 [ 3.278264] blk_update_request: I/O error, dev mmcblk2, sector 746544 [ 3.284671] dwmmc_rockchip ff0f0000.dwmmc: All phases work, using default phase 0. [ 3.284845] mmcblk2: error -84 transferring data, sector 746546, nr 238, cmd response 0x900, card status 0x0 [ 3.284854] blk_update_request: I/O error, dev mmcblk2, sector 746546 [ 3.291271] dwmmc_rockchip ff0f0000.dwmmc: All phases work, using default phase 0. [ 3.291608] mmcblk2: error -84 transferring data, sector 746550, nr 234, cmd response 0x900, card status 0x0 [ 3.291620] blk_update_request: I/O error, dev mmcblk2, sector 746550 [ 3.298044] dwmmc_rockchip ff0f0000.dwmmc: All phases work, using default phase 0. [ 3.298223] mmcblk2: error -84 transferring data, sector 746552, nr 232, cmd response 0x900, card status 0x0 [ 3.298236] blk_update_request: I/O error, dev mmcblk2, sector 746552 [ 3.304661] dwmmc_rockchip ff0f0000.dwmmc: All phases work, using default phase 0. [ 3.305150] mmcblk2: error -84 transferring data, sector 746558, nr 226, cmd response 0x900, card status 0x0 [ 3.305163] blk_update_request: I/O error, dev mmcblk2, sector 746558 [ 3.311562] dwmmc_rockchip ff0f0000.dwmmc: All phases work, using default phase 0. [ 3.311741] mmcblk2: error -84 transferring data, sector 746560, nr 224, cmd response 0x900, card status 0x0 [ 3.311752] blk_update_request: I/O error, dev mmcblk2, sector 746560 [ 3.318157] dwmmc_rockchip ff0f0000.dwmmc: All phases work, using default phase 0. [ 3.318329] mmcblk2: error -84 transferring data, sector 746562, nr 222, cmd response 0x900, card status 0x0 [ 3.324731] dwmmc_rockchip ff0f0000.dwmmc: All phases work, using default phase 0. 二、通过logo dwmmc_rockchip ff0f0000.dwmmc 基本可以肯定是emmc 出现了问题,然后尝试着 降低EMMC clk 然后基本就可以判定是 硬件EMMC 走线有问题了。 |
基于米尔瑞芯微RK3576核心板/开发板的人脸疲劳检测应用方案
2352 浏览 0 评论
2753 浏览 1 评论
2239 浏览 1 评论
3573 浏览 1 评论
4332 浏览 1 评论
GMT+8, 2025-1-23 01:56 , Processed in 0.744775 second(s), Total 72, Slave 56 queries .
