RK3399 Linux 系统测试
一、磁盘读写测试 写磁盘 dd if=/dev/zero of=./test.txt bs=1M count=2000 oflag=direct,nonblock 2000+0 records in 2000+0 records out 2097152000 bytes (2.1 GB, 2.0 GiB) copied, 16.3669 s, 128 MB/s
dd if=/dev/mmcblk1p8 of=/dev/null bs=1M count=2000 iflag=direct,nonblock 2000+0 records in 2000+0 records out 2097152000 bytes (2.1 GB, 2.0 GiB) copied, 9.99422 s, 210 MB/s
dd if=/dev/zero of=/dev/sda bs=1M count=2000 oflag=direct,nonblock 2000+0 records in 2000+0 records out 2097152000 bytes (2.1 GB, 2.0 GiB) copied, 10.9544 s, 191 MB/s
dd if=/dev/sda of=/dev/null bs=1M count=2000 iflag=direct,nonblock 2000+0 records in 2000+0 records out 2097152000 bytes (2.1 GB, 2.0 GiB) copied, 9.35061 s, 224 MB/s |
基于米尔瑞芯微RK3576核心板/开发板的人脸疲劳检测应用方案
1767 浏览 0 评论
2288 浏览 1 评论
1955 浏览 1 评论
3294 浏览 1 评论
4095 浏览 1 评论
GMT+8, 2025-1-14 12:03 , Processed in 0.582765 second(s), Total 40, Slave 34 queries .
