各位大佬好,打扰了。最近尝试在 stm32f413 是使用定时器输入捕获测试频率,用另一个定时器输出 PWM 来测试,结果发现不进中断。不知该如何改了,请问有用过此功能的大佬吗? 请帮忙看一下这样写的是否正确,谢谢! #include <board.h> |
定时器同时捕获4个通道的PWM代码
/* * Copyright (c) 2006-2021, RT-Thread Development Team * * SPDX-License-Identifier: Apache-2.0 * * Change Logs: * Date Author Notes * 2022-09-16 Administrator the first version */ #include #include #include TIM_HandleTypeDef htim8; #define POWER1_CTRL GET_PIN(H,2) /** * @Brief TIM8 Initialization Function * @param None * @retval None */ static void MX_TIM8_Init(void) { /* USER CODE BEGIN TIM8_Init 0 */ /* USER CODE END TIM8_Init 0 */ TIM_ClockConfigTypeDef sClockSourceConfig = {0}; TIM_MasterConfigTypeDef sMasterConfig = {0}; TIM_IC_InitTypeDef sConfigIC = {0}; /* USER CODE BEGIN TIM8_Init 1 */ /* USER CODE END TIM8_Init 1 */ htim8.Instance = TIM8; htim8.Init.Prescaler = 180-1; htim8.Init.CounterMode = TIM_COUNTERMODE_UP; htim8.Init.Period = 65535; htim8.Init.ClockDivision = TIM_CLOCKDIVISION_DIV1; htim8.Init.RepetitionCounter = 0; htim8.Init.AutoReloadPreload = TIM_AUTORELOAD_PRELOAD_DISABLE; if (HAL_TIM_Base_Init(&htim8) != HAL_OK) { Error_Handler(); } sClockSourceConfig.ClockSource = TIM_CLOCKSOURCE_INTERNAL; if (HAL_TIM_ConfigClockSource(&htim8, &sClockSourceConfig) != HAL_OK) { Error_Handler(); } if (HAL_TIM_IC_Init(&htim8) != HAL_OK) { Error_Handler(); } sMasterConfig.MasterOutputTrigger = TIM_TRGO_RESET; sMasterConfig.MasterSlaveMode = TIM_MASTERSLAVEMODE_DISABLE; if (HAL_TIMEx_MasterConfigSynchronization(&htim8, &sMasterConfig) != HAL_OK) { Error_Handler(); } sConfigIC.ICPolarity = TIM_INPUTCHANNELPOLARITY_RISING; sConfigIC.ICSelection = TIM_ICSELECTION_DIRECTTI; sConfigIC.ICPrescaler = TIM_ICPSC_DIV1; sConfigIC.ICFilter = 0; if (HAL_TIM_IC_ConfigChannel(&htim8, &sConfigIC, TIM_CHANNEL_1) != HAL_OK) { Error_Handler(); } if (HAL_TIM_IC_ConfigChannel(&htim8, &sConfigIC, TIM_CHANNEL_2) != HAL_OK) { Error_Handler(); } if (HAL_TIM_IC_ConfigChannel(&htim8, &sConfigIC, TIM_CHANNEL_3) != HAL_OK) { Error_Handler(); } if (HAL_TIM_IC_ConfigChannel(&htim8, &sConfigIC, TIM_CHANNEL_4) != HAL_OK) { Error_Handler(); } __HAL_TIM_DISABLE(&htim8); //关闭定时器8 __HAL_TIM_SET_COUNTER(&htim8,0); HAL_TIM_IC_Start_IT(&htim8,TIM_CHANNEL_1); //开启TIM8的捕获通道1,并且开启捕获中断 HAL_TIM_IC_Start_IT(&htim8,TIM_CHANNEL_2); //开启TIM8的捕获通道2,并且开启捕获中断 HAL_TIM_IC_Start_IT(&htim8,TIM_CHANNEL_3); //开启TIM8的捕获通道3,并且开启捕获中断 HAL_TIM_IC_Start_IT(&htim8,TIM_CHANNEL_4); //开启TIM8的捕获通道4,并且开启捕获中断 __HAL_TIM_ENABLE_IT(&htim8,TIM_IT_UPDATE); //使能更新中断 __HAL_TIM_ENABLE(&htim8);//使能定时器8 } /** * @brief TIM_Base MSP Initialization * This function configures the hardware resources used in this example * @param htim_base: TIM_Base handle pointer * @retval None */ void HAL_TIM_Base_MspInit(TIM_HandleTypeDef* htim_base) { GPIO_InitTypeDef GPIO_InitStruct = {0}; if(htim_base->Instance==TIM8) { /* USER CODE BEGIN TIM8_MspInit 0 */ /* USER CODE END TIM8_MspInit 0 */ /* Peripheral clock enable */ __HAL_RCC_TIM8_CLK_ENABLE(); __HAL_RCC_GPIOI_CLK_ENABLE(); /**TIM8 GPIO Configuration PI7 ------> TIM8_CH3 PI6 ------> TIM8_CH2 PI5 ------> TIM8_CH1 PI2 ------> TIM8_CH4 */ GPIO_InitStruct.Pin = GPIO_PIN_7|GPIO_PIN_6|GPIO_PIN_5|GPIO_PIN_2; GPIO_InitStruct.Mode = GPIO_MODE_AF_PP; GPIO_InitStruct.Pull = GPIO_PULLDOWN; GPIO_InitStruct.Speed = GPIO_SPEED_FREQ_LOW; GPIO_InitStruct.Alternate = GPIO_AF3_TIM8; HAL_GPIO_Init(GPIOI, &GPIO_InitStruct); /* TIM8 interrupt Init */ //HAL_NVIC_SetPriority(TIM8_BRK_TIM12_IRQn, 0, 0); //HAL_NVIC_EnableIRQ(TIM8_BRK_TIM12_IRQn); HAL_NVIC_SetPriority(TIM8_UP_TIM13_IRQn, 0, 0); HAL_NVIC_EnableIRQ(TIM8_UP_TIM13_IRQn); //HAL_NVIC_SetPriority(TIM8_TRG_COM_TIM14_IRQn, 0, 0); //HAL_NVIC_EnableIRQ(TIM8_TRG_COM_TIM14_IRQn); HAL_NVIC_SetPriority(TIM8_CC_IRQn, 0, 0); HAL_NVIC_EnableIRQ(TIM8_CC_IRQn); /* USER CODE BEGIN TIM8_MspInit 1 */ /* USER CODE END TIM8_MspInit 1 */ } } /** * @brief TIM_Base MSP De-Initialization * This function freeze the hardware resources used in this example * @param htim_base: TIM_Base handle pointer * @retval None */ void HAL_TIM_Base_MspDeInit(TIM_HandleTypeDef* htim_base) { if(htim_base->Instance==TIM8) { /* USER CODE BEGIN TIM8_MspDeInit 0 */ /* USER CODE END TIM8_MspDeInit 0 */ /* Peripheral clock disable */ __HAL_RCC_TIM8_CLK_DISABLE(); /**TIM8 GPIO Configuration PI7 ------> TIM8_CH3 PI6 ------> TIM8_CH2 PI5 ------> TIM8_CH1 PI2 ------> TIM8_CH4 */ HAL_GPIO_DeInit(GPIOI, GPIO_PIN_7|GPIO_PIN_6|GPIO_PIN_5|GPIO_PIN_2); /* TIM8 interrupt DeInit */ //HAL_NVIC_DisableIRQ(TIM8_BRK_TIM12_IRQn); HAL_NVIC_DisableIRQ(TIM8_UP_TIM13_IRQn); //HAL_NVIC_DisableIRQ(TIM8_TRG_COM_TIM14_IRQn); HAL_NVIC_DisableIRQ(TIM8_CC_IRQn); /* USER CODE BEGIN TIM8_MspDeInit 1 */ /* USER CODE END TIM8_MspDeInit 1 */ } } void TIM8_UP_TIM13_IRQHandler(void) { HAL_TIM_IRQHandler(&htim8); } /** * @brief This function handles TIM8 capture compare interrupt. */ void TIM8_CC_IRQHandler(void) { HAL_TIM_IRQHandler(&htim8); } //捕获状态 //[7]:0,没有成功的捕获;1,成功捕获到一次. //[6]:0,还没捕获到低电平;1,已经捕获到低电平了. //[5:0]:捕获低电平后溢出的次数(对于32位定时器来说,1us计数器加1,溢出时间:4294秒) rt_uint8_t TIM8CH3_CAPTURE_STA = 0; //输入捕获状态 rt_uint16_t TIM8CH3_CAPTURE_VAL; //输入捕获值(TIM8是16位) rt_uint16_t tim8ch3_cnt_zero; rt_uint8_t TIM8CH4_CAPTURE_STA = 0; //输入捕获状态 rt_uint16_t TIM8CH4_CAPTURE_VAL; //输入捕获值(TIM8是16位) rt_uint16_t tim8ch4_cnt_zero; rt_uint8_t TIM8CH2_CAPTURE_STA = 0; //输入捕获状态 rt_uint16_t TIM8CH2_CAPTURE_VAL; //输入捕获值(TIM8是16位) rt_uint16_t tim8ch2_cnt_zero; rt_uint8_t TIM8CH1_CAPTURE_STA = 0; //输入捕获状态 rt_uint16_t TIM8CH1_CAPTURE_VAL; //输入捕获值(TIM8是16位) rt_uint16_t tim8ch1_cnt_zero; //定时器更新中断(计数溢出)中断处理回调函数, 该函数在HAL_TIM_IRQHandler中会被调用 void HAL_TIM_PeriodElapsedCallback(TIM_HandleTypeDef *htim)//更新中断(溢出)发生时执行 { rt_interrupt_enter(); if((TIM8CH1_CAPTURE_STA & 0X80)==0)//还未成功捕获 { if(TIM8CH1_CAPTURE_STA & 0X40)//已经捕获到高电平了 { if((TIM8CH1_CAPTURE_STA & 0X3F) == 0X3F)//高电平太长了 { TIM8CH1_CAPTURE_STA |= 0X80; //标记成功捕获了一次 TIM8CH1_CAPTURE_VAL = 0XFFFF; } else TIM8CH1_CAPTURE_STA ++; } } if((TIM8CH2_CAPTURE_STA & 0X80)==0)//还未成功捕获 { if(TIM8CH2_CAPTURE_STA & 0X40)//已经捕获到高电平了 { if((TIM8CH2_CAPTURE_STA & 0X3F) == 0X3F)//高电平太长了 { TIM8CH2_CAPTURE_STA |= 0X80; //标记成功捕获了一次 TIM8CH2_CAPTURE_VAL = 0XFFFF; } else TIM8CH2_CAPTURE_STA ++; } } if((TIM8CH3_CAPTURE_STA & 0X80)==0)//还未成功捕获 { if(TIM8CH3_CAPTURE_STA & 0X40)//已经捕获到高电平了 { if((TIM8CH3_CAPTURE_STA & 0X3F) == 0X3F)//高电平太长了 { TIM8CH3_CAPTURE_STA |= 0X80; //标记成功捕获了一次 TIM8CH3_CAPTURE_VAL = 0XFFFF; } else TIM8CH3_CAPTURE_STA ++; } } if((TIM8CH4_CAPTURE_STA & 0X80)==0)//还未成功捕获 { if(TIM8CH4_CAPTURE_STA & 0X40)//已经捕获到高电平了 { if((TIM8CH4_CAPTURE_STA & 0X3F) == 0X3F)//高电平太长了 { TIM8CH4_CAPTURE_STA |= 0X80; //标记成功捕获了一次 TIM8CH4_CAPTURE_VAL = 0XFFFF; } else TIM8CH4_CAPTURE_STA ++; } } rt_interrupt_leave(); } //定时器输入捕获中断处理回调函数,该函数在HAL_TIM_IRQHandler中会被调用 void HAL_TIM_IC_CaptureCallback(TIM_HandleTypeDef *htim)//捕获中断发生时执行 { rt_interrupt_enter(); if(htim->Channel == HAL_TIM_ACTIVE_CHANNEL_1)//捕获1发生捕获事件 { if((TIM8CH1_CAPTURE_STA & 0X80) == 0)//还未成功捕获 { if(TIM8CH1_CAPTURE_STA & 0X40) //捕获到一个下降沿 { TIM8CH1_CAPTURE_STA |= 0X80; //标记成功捕获到一次高电平脉宽 TIM8CH1_CAPTURE_VAL = TIM8->CCR1; TIM8->CCER &= ~(1<<1);//配置TIM8通道2上升沿捕获 } else //还未开始,第一次捕获上升沿 { tim8ch1_cnt_zero = TIM8->CCR1; TIM8CH1_CAPTURE_STA = 0; TIM8CH1_CAPTURE_VAL = 0; TIM8CH1_CAPTURE_STA |= 0X40; //标记捕获到了上升沿 TIM8->CCER |= 1<<1;//定时器8通道2设置为下降沿捕获 } } } if(htim->Channel == HAL_TIM_ACTIVE_CHANNEL_2)//捕获2发生捕获事件 { if((TIM8CH2_CAPTURE_STA & 0X80) == 0)//还未成功捕获 { if(TIM8CH2_CAPTURE_STA & 0X40) //捕获到一个下降沿 { TIM8CH2_CAPTURE_STA |= 0X80; //标记成功捕获到一次高电平脉宽 TIM8CH2_CAPTURE_VAL = TIM8->CCR2; TIM8->CCER &= ~(1<<5);//配置TIM8通道2上升沿捕获 } else //还未开始,第一次捕获上升沿 { tim8ch2_cnt_zero = TIM8->CCR2; TIM8CH2_CAPTURE_STA = 0; TIM8CH2_CAPTURE_VAL = 0; TIM8CH2_CAPTURE_STA |= 0X40; //标记捕获到了上升沿 TIM8->CCER |= 1<<5;//定时器8通道2设置为下降沿捕获 } } } if(htim->Channel == HAL_TIM_ACTIVE_CHANNEL_3)//捕获3发生捕获事件 { if((TIM8CH3_CAPTURE_STA & 0X80) == 0)//还未成功捕获 { if(TIM8CH3_CAPTURE_STA & 0X40) //捕获到一个下降沿 { TIM8CH3_CAPTURE_STA |= 0X80; //标记成功捕获到一次高电平脉宽 TIM8CH3_CAPTURE_VAL = TIM8->CCR3; TIM8->CCER &= ~(1<<9);//配置TIM8通道3上升沿捕获 } else //还未开始,第一次捕获上升沿 { tim8ch3_cnt_zero = TIM8->CCR3; TIM8CH3_CAPTURE_STA = 0; TIM8CH3_CAPTURE_VAL = 0; TIM8CH3_CAPTURE_STA |= 0X40; //标记捕获到了上升沿 TIM8->CCER |= 1<<9;//定时器8通道3设置为下降沿捕获 } } } if(htim->Channel == HAL_TIM_ACTIVE_CHANNEL_4)//捕获4发生捕获事件 { if((TIM8CH4_CAPTURE_STA & 0X80) == 0)//还未成功捕获 { if(TIM8CH4_CAPTURE_STA & 0X40) //捕获到一个下降沿 { TIM8CH4_CAPTURE_STA |= 0X80; //标记成功捕获到一次高电平脉宽 TIM8CH4_CAPTURE_VAL = TIM8->CCR4; TIM8->CCER &= ~(1<<13);//配置TIM8通道3上升沿捕获 } else //还未开始,第一次捕获上升沿 { tim8ch4_cnt_zero = TIM8->CCR4; TIM8CH4_CAPTURE_STA = 0; TIM8CH4_CAPTURE_VAL = 0; TIM8CH4_CAPTURE_STA |= 0X40; //标记捕获到了上升沿 TIM8->CCER |= 1<<13;//定时器8通道3设置为下降沿捕获 } } } rt_interrupt_leave(); } extern float robot_aims_speed; extern rt_uint8_t mknm4_fx; void forword_check_speed(rt_uint16_t spedd) { float sed_spd_f = 0; if(spedd > 550) { mknm4_fx = 0x09; sed_spd_f = (float)spedd; sed_spd_f = sed_spd_f - 550; robot_aims_speed = sed_spd_f * 0.001; } else if(spedd < 450) { mknm4_fx = 0x06; sed_spd_f = (float)spedd; sed_spd_f = 450 - sed_spd_f; robot_aims_speed = sed_spd_f * 0.001; } else { mknm4_fx = 0x00; robot_aims_speed = 0.0; } } void leftright_check_speed(rt_uint16_t lrdata) { float sed_spd_f = 0; if(lrdata > 550) { mknm4_fx = 0x0F; sed_spd_f = (float)lrdata; sed_spd_f = sed_spd_f - 550; robot_aims_speed = sed_spd_f * 0.001; } else if(lrdata < 450) { mknm4_fx = 0x00; sed_spd_f = (float)lrdata; sed_spd_f = 450 - sed_spd_f; robot_aims_speed = sed_spd_f * 0.001; } else { mknm4_fx = 0x00; robot_aims_speed = 0.0; } } void zhuanxiang_check_speed(rt_uint16_t lrdata) { float sed_spd_f = 0; if(lrdata > 550) { mknm4_fx = 0x00; sed_spd_f = (float)lrdata; sed_spd_f = sed_spd_f - 550; robot_aims_speed = sed_spd_f * 0.0005; } else if(lrdata < 450) { mknm4_fx = 0x0f; sed_spd_f = (float)lrdata; sed_spd_f = 450 - sed_spd_f; robot_aims_speed = sed_spd_f * 0.0005; } else { mknm4_fx = 0x00; robot_aims_speed = 0.0; } } void forback_leftright(rt_uint16_t fbdata,rt_uint16_t lrdata) { float sed_spd_f = 0; if(fbdata > 550) { if(lrdata > 550) { mknm4_fx = 0x52; sed_spd_f = (float)lrdata; sed_spd_f = sed_spd_f - 550; robot_aims_speed = sed_spd_f * 0.0005; rt_kprintf("1n"); } else if(lrdata < 450) { mknm4_fx = 0x58; sed_spd_f = (float)lrdata; sed_spd_f = 450 - sed_spd_f; robot_aims_speed = sed_spd_f * 0.0005; rt_kprintf("2n"); } } else if(fbdata < 450) { if(lrdata > 550) { mknm4_fx = 0xa1; sed_spd_f = (float)lrdata; sed_spd_f = sed_spd_f - 550; robot_aims_speed = sed_spd_f * 0.0005; rt_kprintf("3 = %dn",lrdata); } else if(lrdata < 450) { mknm4_fx = 0xa4; sed_spd_f = (float)lrdata; sed_spd_f = 450 - sed_spd_f; robot_aims_speed = sed_spd_f * 0.0005; //rt_kprintf("4 = %dn",lrdata); } } else { mknm4_fx = 0x00; robot_aims_speed = 0.0; } } extern rt_uint8_t mknm4_lock_flag; rt_uint32_t extern_tmp_ch3 = 0; #define CSB_PRIORITY 15//任务优先级 static char csb_stack[800]; static struct rt_thread csb_thread; static void csb_entry(void *parameter) { rt_uint8_t print_ct = 0; rt_uint32_t tmp_ch4 = 0; rt_uint32_t tmp_ch3 = 0; rt_uint32_t tmp_ch2 = 0; rt_uint32_t tmp_ch1 = 0; rt_thread_mdelay(2000); MX_TIM8_Init(); rt_pin_mode(POWER1_CTRL, PIN_MODE_OUTPUT); rt_pin_write(POWER1_CTRL, PIN_HIGH); while(1) { rt_thread_mdelay(10); if(TIM8CH1_CAPTURE_STA & 0X80) //成功捕获到了一次高电平 { if((TIM8CH1_CAPTURE_STA & 0X3F) == 0)//还没有溢出过 tmp_ch1 = TIM8CH1_CAPTURE_VAL - tim8ch1_cnt_zero; else tmp_ch1 = (0XFFFF - tim8ch1_cnt_zero) + TIM8CH1_CAPTURE_VAL; if(tmp_ch1 > 2000)//油门通道 { tmp_ch1 = 2000; } else if(tmp_ch1 < 1000) { tmp_ch1 = 1000; } tmp_ch1 = tmp_ch1 - 1000; if(tmp_ch1 < 100) tmp_ch1 = 0; TIM8CH1_CAPTURE_STA = 0; } if(TIM8CH2_CAPTURE_STA & 0X80) //成功捕获到了一次高电平 { if((TIM8CH2_CAPTURE_STA & 0X3F) == 0)//还没有溢出过 tmp_ch2 = TIM8CH2_CAPTURE_VAL - tim8ch2_cnt_zero; else tmp_ch2 = (0XFFFF - tim8ch2_cnt_zero) + TIM8CH2_CAPTURE_VAL; if(tmp_ch2 > 2000)//油门通道 { tmp_ch2 = 2000; } else if(tmp_ch2 < 1000) { tmp_ch2 = 1000; } tmp_ch2 = tmp_ch2 - 1000; if(tmp_ch2 < 100) tmp_ch2 = 0; TIM8CH2_CAPTURE_STA = 0; } if(TIM8CH3_CAPTURE_STA & 0X80) //成功捕获到了一次高电平 { if((TIM8CH3_CAPTURE_STA & 0X3F) == 0)//还没有溢出过 tmp_ch3 = TIM8CH3_CAPTURE_VAL - tim8ch3_cnt_zero; else tmp_ch3 = (0XFFFF - tim8ch3_cnt_zero) + TIM8CH3_CAPTURE_VAL; if(tmp_ch3 > 2000)//左右通道 { tmp_ch3 = 2000; } else if(tmp_ch3 < 1000) { tmp_ch3 = 1000; } tmp_ch3 = tmp_ch3 - 1000; TIM8CH3_CAPTURE_STA = 0; } if(TIM8CH4_CAPTURE_STA & 0X80) //成功捕获到了一次高电平 { if((TIM8CH4_CAPTURE_STA & 0X3F) == 0)//还没有溢出过 tmp_ch4 = TIM8CH4_CAPTURE_VAL - tim8ch4_cnt_zero; else tmp_ch4 = (0XFFFF - tim8ch4_cnt_zero) + TIM8CH4_CAPTURE_VAL; if(tmp_ch4 > 2000)//前后通道 { tmp_ch4 = 2000; } else if(tmp_ch4 < 1000) { tmp_ch4 = 1000; } tmp_ch4 = tmp_ch4 - 1000; TIM8CH4_CAPTURE_STA = 0; } //右手、前ch3-->1000,后ch3-->0,前后走 if(((tmp_ch3 < 450) || (tmp_ch3 > 550)) && ((tmp_ch2 < 450) || (tmp_ch2 > 550))) { //forback_leftright(tmp_ch2,tmp_ch3); mknm4_lock_flag = 0; } else if((tmp_ch3 < 450) || (tmp_ch3 > 550)) { //forword_check_speed(tmp_ch3); mknm4_lock_flag = 0; } /* if(tmp_ch3 < 100) { mknm4_lock_flag = 0; mknm4_fx = 0x0F; robot_aims_speed = 0.2; } */ if((tmp_ch3 < 200)) { //右手、左ch1-->1000,右ch1-->0,横走 if((tmp_ch1 < 450) || (tmp_ch1 > 550)) { leftright_check_speed(tmp_ch1); mknm4_lock_flag = 0; } else { mknm4_lock_flag = 1; mknm4_fx = 0x00; robot_aims_speed = 0.0; } } else { mknm4_lock_flag = 1; mknm4_fx = 0x00; robot_aims_speed = 0.0; } if(tmp_ch1 == 0 && tmp_ch2 == 0 && tmp_ch3 == 0 && tmp_ch4 == 0) { mknm4_lock_flag = 1; mknm4_fx = 0x00; robot_aims_speed = 0.0; } print_ct ++; if(print_ct > 100) { print_ct = 0; rt_kprintf("CH1 = %d,CH2 = %d,CH3 = %d,CH5 = %dn",tmp_ch1,tmp_ch2,tmp_ch3,tmp_ch4); } extern_tmp_ch3 = tmp_ch3; } } static int csb_sample(void) { rt_thread_init(&csb_thread, "csbsample", csb_entry, RT_NULL, &csb_stack[0], sizeof(csb_stack), CSB_PRIORITY,100); rt_thread_startup(&csb_thread); return 0; } INIT_APP_EXPORT(csb_sample); |
943 浏览 0 评论
AI模型部署边缘设备的奇妙之旅:如何在边缘端部署OpenCV
3154 浏览 0 评论
tms320280021 adc采样波形,为什么adc采样频率上来波形就不好了?
1426 浏览 0 评论
2072 浏览 0 评论
1595 浏览 0 评论
75177 浏览 21 评论
GMT+8, 2024-12-27 02:27 , Processed in 0.483714 second(s), Total 41, Slave 35 queries .
