我们正在设计基于 NXP i.MX8QXP 参考板 (i.MX8QXP-MEK) 的定制板。
在我们的设置中,我们无法使用 PCIe 接口与 Wifi 外部模块通信。然而,与 MEK 不同的是,我们使用板载焊接模块,而不是 M.2 卡插槽 内核日志消息指出 PHY 链接阶段出现错误,并且出现“phy link never came up”,以及错误-110: [ 1.424457] ehci-pci: EHCI PCI platform driver [ 1.441283] ohci-pci: OHCI PCI platform driver [ 2.809918] imx6q-pcie 5f010000.pcie: No cache used with register defaults set! [ 2.845346] imx6q-pcie 5f010000.pcie: PCIe PLL is locked. [ 2.860583] imx6q-pcie 5f010000.pcie: iATU unroll: disabled [ 2.866237] imx6q-pcie 5f010000.pcie: Detected iATU regions: 6 outbound, 6 inbound [ 2.873907] imx6q-pcie 5f010000.pcie: host bridge /bus@5f000000/pcie@0x5f010000 ranges: [ 2.889200] imx6q-pcie 5f010000.pcie: IO 0x007ff80000..0x007ff8ffff -> 0x0000000000 [ 2.905010] imx6q-pcie 5f010000.pcie: MEM 0x0070000000..0x007fefffff -> 0x0070000000 [ 2.921022] imx6q-pcie 5f010000.pcie: iATU unroll: disabled [ 2.934114] imx6q-pcie 5f010000.pcie: Detected iATU regions: 6 outbound, 6 inbound [ 3.935037] imx6q-pcie 5f010000.pcie: Phy link never came up [ 3.940769] imx6q-pcie 5f010000.pcie: PHY DEBUG_R0=0x00007e00 DEBUG_R1=0x08200000 [ 3.941390] imx6q-pcie: probe of 5f010000.pcie failed with error -110 设备树中的 PCIeb 节点与 MEK 基本相同——我们设置了一个固定的较低链接速度和一个(当前未使用的)disable-gpio 引脚: &pcieb{ compatible = "fsl,imx8qxp-pcie","snps,dw-pcie"; pinctrl-names = "default"; pinctrl-0 = <&pinctrl_pcieb>; pinctrl-1 = <&pinctrl_wifi_init>; //disable-gpio = <&lsio_gpio1 3 GPIO_ACTIVE_LOW>; reset-gpio = <&lsio_gpio4 0 GPIO_ACTIVE_LOW>; clkreq-gpio = <&lsio_gpio4 1 GPIO_ACTIVE_LOW>; ext_osc = <1>; fsl,max-link-speed = <1>; status = "okay"; }; pinctrl_wifi_init: wifi_initgrp{ fsl,pins = < /* reserve pin init/idle_state to support multiple wlan cards */ IMX8QXP_SPI2_SCK_LSIO_GPIO1_IO03 0x06000021 >; }; 一个显着的区别是 VDD_PCIE_DIG_1P8_3P3引脚——我们在定制板中将其设置为 1v8。但是,MEK 板使用 3v3。 定制板
1934个成员聚集在这个小组
36421 浏览 0 评论
4928 浏览 1 评论
6109 浏览 1 评论
6819 浏览 0 评论
4249 浏览 0 评论
653浏览 2评论
646浏览 2评论
647浏览 2评论
736浏览 2评论
848浏览 2评论
GMT+8, 2024-12-26 05:04 , Processed in 1.375260 second(s), Total 75, Slave 59 queries .
