我正在努力将 SJA1105Q 以太网交换机添加到 Renesas SOC。将 sja1105.ko 文件加载到内核后,观察到内核崩溃。步骤和内核崩溃日志如下所示。
[ 1.585783] systemd-modules-load[207]: Inserted module 'phylink' [ 1.590334] systemd-modules-load[207]: Inserted module 'dsa_core' [ 1.592509] PTP clock support registered [ 1.592587] systemd-modules-load[207]: Inserted module 'ptp' [ 1.594032] systemd-modules-load[207]: Inserted module 'tag_8021q' [ 1.595539] systemd-modules-load[207]: Inserted module 'tag_sja1105' [ 1.599692] sja1105 spi3.1: calling sja1105_probe... [ 1.621283] Unable to handle kernel NULL pointer dereference at virtual address 0000000000000028 [ 1.630106] Mem abort info: [ 1.632900] ESR = 0x96000005 [ 1.636001] EC = 0x25: DABT (current EL), IL = 32 bits [ 1.641328] SET = 0, FnV = 0 [ 1.644381] EA = 0, S1PTW = 0 [ 1.647530] Data abort info: [ 1.650417] ISV = 0, ISS = 0x00000005 [ 1.654262] CM = 0, WnR = 0 [ 1.657231] user pgtable: 4k pages, 39-bit VAs, pgdp=00000004d69f4000 [ 1.663702] [0000000000000028] pgd=0000000000000000, pud=0000000000000000 [ 1.670515] Internal error: Oops: 96000005 [#1] PREEMPT SMP [ 1.676095] Modules linked in: sja1105(+) tag_sja1105 tag_8021q ptp dsa_core phylink cp210x pl2303 ftdi_sio usbserial can_isotp(O) mcp25xxfd sd_mod usb_f_ncm u_ether libcomposite renesas_usbhs udc_core extcon_core xhci_plat_hcd xhci_hcd cdc_ncm hid_generic usbhid usb_storage scsi_mod asix ax88179_178a usbnet mii ehset spidev configfs [ 1.705731] CPU: 1 PID: 207 Comm: systemd-modules Tainted: G O 5.4.26-work #2 [ 1.714179] Hardware name: PCC VBOX (ZR3-Based) board (DT) [ 1.719671] pstate: 40000005 (nZcv daif -PAN -UAO) [ 1.724483] pc : sja1105_probe+0x130/0x2b8 [sja1105] [ 1.729456] lr : sja1105_probe+0x120/0x2b8 [sja1105] [ 1.734424] sp : ffffffc010c1b900 [ 1.737738] x29: ffffffc010c1b900 x28: 0000000000000001 [ 1.743056] x27: ffffff849565bec8 x26: 0000000000000001 [ 1.748373] x25: ffffffc008845110 x24: 0000000000000010 [ 1.753691] x23: 0000000000000000 x22: ffffffc010928000 [ 1.759007] x21: 0000000000000000 x20: ffffff8497de7800 [ 1.764324] x19: ffffff8495659080 x18: 000000000000000a [ 1.769641] x17: 0000000000000000 x16: 0000000000000000 [ 1.774958] x15: ffffffc48f087000 x14: 00000000000002e7 [ 1.780274] x13: 0000000000000231 x12: 0000000000000038 [ 1.785591] x11: 0101010101010101 x10: 7f7f7f7f7f7f7f7f [ 1.790908] x9 : 03fefeff01fefeff x8 : 7f7f7f7f7f7f7f7f [ 1.796226] x7 : ff342f3030606972 x6 : 0000000000000080 [ 1.801542] x5 : 8000000000000000 x4 : 0000000000000004 [ 1.806859] x3 : ffffffc010c1b940 x2 : 0035303131616a73 [ 1.812176] x1 : ffffff84960c0fc0 x0 : 0000000000000000 [ 1.817493] Call trace: [ 1.819945] sja1105_probe+0x130/0x2b8 [sja1105] [ 1.824576] spi_drv_probe+0x88/0xb0 [ 1.828156] really_probe+0x1e8/0x2ec [ 1.831821] driver_probe_device+0xd8/0xe8 [ 1.835920] device_driver_attach+0x48/0x70 [ 1.840106] __driver_attach+0xc4/0xc8 [ 1.843858] bus_for_each_dev+0x8c/0xd4 [ 1.847696] driver_attach+0x30/0x3c [ 1.851273] bus_add_driver+0x17c/0x1c0 [ 1.855112] driver_register+0xb0/0xe8 [ 1.858862] __spi_register_driver+0x6c/0x78 [ 1.863142] sja1105_driver_init+0x28/0x1000 [sja1105] [ 1.868290] do_one_initcall+0xc4/0x21c [ 1.872130] do_init_module+0x60/0x1f8 [ 1.875880] load_module+0x1dd8/0x1e84 [ 1.879630] __do_sys_finit_module+0xa4/0xc0 [ 1.883902] __arm64_sys_finit_module+0x28/0x34 [ 1.888438] el0_svc_common.constprop.2+0xec/0x158 [ 1.893233] el0_svc_handler+0x58/0x88 [ 1.896984] el0_svc+0x8/0xc [ 1.899869] Code: f900b660 d2800084 b90057bf 910103a3 (f9401418) [ 1.905971] ---[ end trace ff0846ac68861238 ]--- 设备连接和 DTS 详细信息如下所示。 设备连接: 设备树配置: /* SPI_ETH */ &msiof3 { pinctrl-0 = <&msiof3_pins>; pinctrl-names = "default"; status = "okay"; cs-gpios = <0>, <&gpio1 5 GPIO_ACtiVE_LOW>; num-cs = <2>; /*renesas,dtdl = <50>;*/ /*renesas,syncdl = <50>;*/ /* SPI3 CS2-SJA1105 mode 1 */ sja1105@1 { /*compatible = "renesas,sh-msiof";*/ compatible = "nxp,sja1105t"; reg = <1>; spi-max-frequency = <4000000>; spi-cpha; /*spi-cpol;*/ renesas,dtdl = <200>; renesas,syncdl = <300>; reset-gpios = <&gpio4 7 GPIO_ACTIVE_LOW>; ports { #address-cells = <1>; #size-cells = <0>; port@0 { /* Internal port connected to ethernet port of m3 */ ethernet = <&avb>; phy-handle = <&phy0>; phy-mode = "rgmii"; reg = <0>; sja1105,role-phy; fixed-link { speed = <1000>; full-duplex; }; }; port@1 { /* ETH3 (goes to backplane) */ label = "swp1"; phy-handle = <&mii_eth_phy3>; phy-mode = "mii"; reg = <1>; /* Implicit "sja1105,role-mac;" */ }; port@2 { /* brr phy 1 (goes to backplane) */ label = "swp2"; phy-handle = <&mii_brr_phy1>; phy-mode = "mii"; reg = <2>; /* Implicit "sja1105,role-mac;" */ }; port@3 { /* brr phy 2 (goes to backplane) */ phy-handle = <&mii_brr_phy2>; label = "swp3"; phy-mode = "mii"; reg = <3>; /* Implicit "sja1105,role-mac;" */ }; port@4 { /* brr phy 3 (goes to backplane) */ label = "swp4"; phy-handle = <&mii_brr_phy3>; phy-mode = "mii"; reg = <0>; /* Implicit "sja1105,role-mac;" */ }; }; }; }; &avb { pinctrl-0 = <&avb_pins>; pinctrl-names = "default"; renesas,no-ether-link; phy-handle = <&phy0>; status = "okay"; phy-mode = "rgmii-id"; phy0: dummy_phy { compatible = "ethernet-phy-idFFFF.FFFE"; reg = <8>; fixed-link { speed = <1000>; full-duplex; }; }; mii_eth_phy3: ksz9031@0 { compatible = "microchip,ksz9031"; reg = <0>; interrupt-parent = <&gpio4>; interrupts = <17 IRQ_TYPE_LEVEL_LOW>; }; mii_brr_phy1: mv88q2112@1 { compatible = "marvell,mv88q2112"; reg = <1>; interrupt-parent = <&gpio2>; interrupts = <10 IRQ_TYPE_LEVEL_LOW>; reset-gpios = <&gpio4 13 GPIO_ACTIVE_LOW>; }; mii_brr_phy2: mv88q2112@2 { compatible = "marvell,mv88q2112"; reg = <2>; interrupt-parent = <&gpio2>; interrupts = <11 IRQ_TYPE_LEVEL_LOW>; reset-gpios = <&gpio4 12 GPIO_ACTIVE_LOW>; }; mii_brr_phy3: mv88q2112@3 { compatible = "marvell,mv88q2112"; reg = <3>; interrupt-parent = <&gpio2>; interrupts = <12 IRQ_TYPE_LEVEL_LOW>; reset-gpios = <&gpio4 11 GPIO_ACTIVE_LOW>; }; }; 版本细节是。
请检查配置并帮助修复内核崩溃。 |
1.596464] systemd-modules-load[207]: Inserted module 'tag_8021q'[ 1.600014] systemd-modules-load[207]: Inserted module 'sja1105q'[ 1.602380] sja1105 2e1a0000.etop-ffffffff: failed to reset device, err=-61
步骤: 1. 确保系统和内核版本与 sja1105.ko 模块的要求匹配。 2. 检查是否加载了所有依赖模块(如上所示)。如果有任何缺少的依赖项,加载它们。 3. 检查 sja1105.ko 文件是否正确安装到系统中。如果不是,请卸载文件并重新安装。 4. 检查 sja1105.ko 文件是否与 SOC 的体系结构匹配。如果不是,请寻找适当的文件并将其安装到系统中。 5. 检查系统日志以查看更多有关崩溃的信息。存在其他错误吗?如果有,请尝试通过修复这些错误来解决崩溃。 6. 尝试使用其他版本的 sja1105.ko 文件,以查看是否存在文件版本兼容性问题。 7. 如果以上步骤均无法解决崩溃问题,请联系 sja1105.ko 文件的供应商以获取支持。 |
1935个成员聚集在这个小组
36428 浏览 0 评论
4981 浏览 1 评论
6114 浏览 1 评论
6821 浏览 0 评论
4252 浏览 0 评论
654浏览 2评论
646浏览 2评论
647浏览 2评论
737浏览 2评论
849浏览 2评论
GMT+8, 2024-12-27 09:57 , Processed in 1.063784 second(s), Total 47, Slave 41 queries .
