raceback (most recent call last):
File "/root/esp-matter/connectedhomeip/connectedhomeip/third_party/pigweed/repo/pw_env_setup/py/pw_env_setup/env_setup.py", line 995, in sys.exit(main()) File "/root/esp-matter/connectedhomeip/connectedhomeip/third_party/pigweed/repo/pw_env_setup/py/pw_env_setup/env_setup.py", line 987, in main return EnvSetup(**vars(parse())).setup() File "/root/esp-matter/connectedhomeip/connectedhomeip/third_party/pigweed/repo/pw_env_setup/py/pw_env_setup/env_setup.py", line 577, in setup result = step(spin) File "/root/esp-matter/connectedhomeip/connectedhomeip/third_party/pigweed/repo/pw_env_setup/py/pw_env_setup/env_setup.py", line 671, in cipd cipd_client = cipd_wrapper.init( File "/root/esp-matter/connectedhomeip/connectedhomeip/third_party/pigweed/repo/pw_env_setup/py/pw_env_setup/cipd_setup/wrapper.py", line 378, in init bootstrap(client, silent, rosetta=rosetta) File "/root/esp-matter/connectedhomeip/connectedhomeip/third_party/pigweed/repo/pw_env_setup/py/pw_env_setup/cipd_setup/wrapper.py", line 328, in bootstrap tmp.write(client_bytes(rosetta)) File "/root/esp-matter/connectedhomeip/connectedhomeip/third_party/pigweed/repo/pw_env_setup/py/pw_env_setup/cipd_setup/wrapper.py", line 228, in client_bytes conn = https_connect_with_proxy(CIPD_HOST) File "/root/esp-matter/connectedhomeip/connectedhomeip/third_party/pigweed/repo/pw_env_setup/py/pw_env_setup/cipd_setup/wrapper.py", line 201, in https_connect_with_proxy conn = httplib.HTTPSConnection(url.hostname, url.port) File "/usr/lib/python3.10/http/client.py", line 1410, in __init__ super(HTTPSConnection, self).__init__(host, port, timeout, File "/usr/lib/python3.10/http/client.py", line 852, in __init__ (self.host, self.port) = self._get_hostport(host, port) File "/usr/lib/python3.10/http/client.py", line 886, in _get_hostport i = host.rfind(':') AttributeError: 'NoneType' object has no attribute 'rfind' |
根据您提供的错误信息,这个问题发生在安装 Matter (基于 Project CHIP 的智能家居协议) 的过程中。错误信息显示在执行 `/root/esp-matter/connectedhomeip/connectedhomeip/third_party/pigweed/repo/pw_env_setup/py/pw_env_setup/env_setup.py` 脚本时发生了问题。
以下是一些可能导致这个问题的原因: 1. **依赖问题**:安装过程中可能缺少某些必需的依赖项。请确保您已经按照 Matter 的安装指南安装了所有必要的依赖。 2. **权限问题**:执行脚本时可能没有足够的权限。您可以尝试使用 `sudo` 来运行脚本,以确保有足够的权限。 3. **Python 版本问题**:脚本可能需要特定版本的 Python。请检查 Matter 的安装指南,确保您使用的 Python 版本与要求相匹配。 4. **脚本错误**:`env_setup.py` 脚本本身可能存在错误。这可能是由于代码问题或与您的系统不兼容。您可以尝试查找是否有其他人遇到类似问题,并查看他们是如何解决问题的。 5. **环境变量问题**:环境变量设置不正确也可能导致问题。请检查您的环境变量设置,确保它们与 Matter 的要求一致。 6. **文件损坏**:下载或提取 Matter 源代码时,文件可能已损坏。尝试重新下载或提取源代码。 7. **系统兼容性问题**:您的系统可能与 Matter 的某些组件不兼容。请检查 Matter 的系统要求,确保您的系统满足这些要求。 为了解决这个问题,您可以尝试以下步骤: - 确保所有依赖项都已正确安装。 - 使用 `sudo` 运行脚本,以确保有足够的权限。 - 检查 Python 版本是否符合 Matter 的要求。 - 查找是否有其他人遇到类似问题,并查看他们的解决方案。 - 重新下载或提取 Matter 源代码。 - 检查您的系统是否满足 Matter 的系统要求。 如果问题仍然存在,您可以尝试联系 Matter 的开发团队或在相关william hill官网 上寻求帮助。 |
423 浏览 1 评论
1280 浏览 1 评论
596浏览 6评论
491浏览 5评论
478浏览 5评论
474浏览 4评论
460浏览 4评论
GMT+8, 2025-1-9 05:50 , Processed in 0.960266 second(s), Total 80, Slave 63 queries .
