电子发烧友william hill官网
1. 您可以选用你所用处理器的硬件SPI配置或用MCU I/O软件模拟SPI通讯。
2. ADS8881 SPI s时序请参考datasheet FIigure 1 和 Figure 51。 |
您好!关于ADS8881模拟SPI通信,我为您提供一个简单的示例代码。这个代码是基于Arduino平台的,您可以根据您的实际需求进行修改。以下是示例代码:
```cpp #include // ADS8881引脚定义 #define ADS8881_CS_PIN 10 // CS引脚连接到Arduino的10号引脚 #define ADS8881_CLK_PIN 13 // CLK引脚连接到Arduino的13号引脚 #define ADS8881_DIN_PIN 11 // DIN引脚连接到Arduino的11号引脚 #define ADS8881_DOUT_PIN 12 // DOUT引脚连接到Arduino的12号引脚 // ADS8881命令定义 #define ADS8881_CMD_WAKEUP 0x00 #define ADS8881_CMD_READ 0x10 #define ADS8881_CMD_WRITE 0x30 #define ADS8881_CMD_IDLE 0xF8 // SPI通信函数 void spi_transfer(uint8_t data) { digitalWrite(ADS8881_DIN_PIN, data & 0x80); digitalWrite(ADS8881_CLK_PIN, LOW); digitalWrite(ADS8881_CLK_PIN, HIGH); data <<= 1; digitalWrite(ADS8881_DIN_PIN, data & 0x80); digitalWrite(ADS8881_CLK_PIN, LOW); digitalWrite(ADS8881_CLK_PIN, HIGH); data <<= 1; digitalWrite(ADS8881_DIN_PIN, data & 0x80); digitalWrite(ADS8881_CLK_PIN, LOW); digitalWrite(ADS8881_CLK_PIN, HIGH); data <<= 1; digitalWrite(ADS8881_DIN_PIN, data & 0x80); digitalWrite(ADS8881_CLK_PIN, LOW); digitalWrite(ADS8881_CLK_PIN, HIGH); data <<= 1; digitalWrite(ADS8881_DIN_PIN, data & 0x80); digitalWrite(ADS8881_CLK_PIN, LOW); digitalWrite(ADS8881_CLK_PIN, HIGH); } // ADS8881初始化函数 void ads8881_init() { pinMode(ADS8881_CS_PIN, OUTPUT); pinMode(ADS8881_CLK_PIN, OUTPUT); pinMode(ADS8881_DIN_PIN, OUTPUT); pinMode(ADS8881_DOUT_PIN, INPUT); digitalWrite(ADS8881_CS_PIN, HIGH); digitalWrite(ADS8881_CLK_PIN, LOW); digitalWrite(ADS8881_DIN_PIN, LOW); // 发送Wakeup命令 digitalWrite(ADS8881_CS_PIN, LOW); spi_transfer(ADS8881_CMD_WAKEUP); digitalWrite(ADS8881_CS_PIN, HIGH); } // ADS8881读取函数 uint16_t ads8881_read() { uint16_t result = 0; // 发送Read命令 digitalWrite(ADS8881_CS_PIN, LOW); spi_transfer(ADS8881_CMD_READ); result = spi_transfer(0x00) << 8; result |= spi_transfer(0x00); digitalWrite(ADS8881_CS_PIN, HIGH); return result; } void setup() { ads8881_init(); } void loop() { uint16_t value = ads8881_read(); Serial.println(value); delay(1000); } ``` 这个示例代码首先定义了ADS8881的引脚和命令,然后实现了SPI通信函数`spi_transfer`和ADS8881的初始化、读取函数。在`setup`函数中进行ADS8881的初始化,在`loop`函数中每隔1秒读取一次数据并通过串口输出。 请根据您的实际硬件连接和需求进行修改。希望这个示例代码对您有所帮助! |
2904个成员聚集在这个小组
加入小组348 浏览 1 评论
543 浏览 2 评论
786 浏览 3 评论
658 浏览 1 评论
1140 浏览 1 评论
76浏览 29评论
253浏览 23评论
261浏览 20评论
209浏览 14评论
67浏览 13评论
GMT+8, 2024-12-26 16:17 , Processed in 0.975975 second(s), Total 85, Slave 68 queries .
