嗨,
在Dell Ultrasharp 3415w上使用GRID K2配置文件时,我遇到了这个奇怪的问题,原始分辨率为3440x1440。
我正在使用VMware Horizon 7.0和戴尔的P45零客户端。
问题如下:
当我想使用GRID K2 GPU时,显示器会一直闪烁,每秒都会打开和关闭,所以我什么也做不了。
如果我在dell poweredge服务器上使用板载Matrox卡,我可以在通过相同设备的显示器的原始分辨率下运行没有任何问题。
如果我将我的显示器更改为标准显示器,那么GRID就可以正常工作。
有些东西肯定是错的,在我看来,分辨率视图通过PCOIP发送不与显示器同步。
有没有办法改变GRID配置文件的最大分辨率,让我的3440x1440或实际强制视图发送我知道我的显示器可以处理的分辨率?
非常感谢。
以上来自于谷歌翻译
以下为原文
Hi,
I have this strange problem when using GRID K2 profiles on a Dell Ultrasharp 3415w which the native resolution is 3440x1440.
I am using VMware Horizon 7.0 with P45 zero clients from Dell. The problem is the following :
When I want to use the GRID K2 GPU, the monitor keeps flickering, goes on and off every second so I cannot do anything.
If I use the onboard Matrox card on my dell poweredge servers I can operate no problems at the native resolution of the monitor going through the same devices. If I change my monitor to a standard one, then GRID works just fine.
Something is definitely wrong, it seems to me that the resolution view is sending over the PCOIP is not synching with the monitor.
Is there a way to change the maximum resolution of the GRID profiles to have my 3440x1440 or actually force view to send a resolution I know my monitor can handle ?
Thanks much appreciated.
嗨,
问题如下:
非常感谢。
以上来自于谷歌翻译
以下为原文
Hi,
