雷切尔的信息绝对准确。
RemoteFX虚拟图形适配器使用API拦截机制,该机制从来宾VM中的Microsoft驱动程序转换API调用,并将这些调用传递给Hyper-V主机中的硬件驱动程序。
您在K2上看到的是Microsoft驱动程序拦截并转换这些API调用并将它们传递给Hyper-V主机中的Nvidia驱动程序。
值得注意的还有几点
Remote FX虚拟图形适配器仅在功能齐全的RemoteFX会话中启用,任何其他连接方法都禁用它。
它也仅限于DirectX,2012R2版本不支持OpenGL(虽然Server 2016可以)。
所以我很惊讶你看到Solidworks使用GPU(它可能在非常低的功能级别上运行在CPU上)。
无论如何,你问过M60对Hyper-V的支持。
对于M60,目前还没有正式的裸机部署支持,这种类型的安装是因为它安装在Server 2012R2中(不支持核心服务,你必须拥有GUI)。
有几个原因可能会在未来发生变化。
但是,如果您很高兴测试不支持的功能,Tesla M60在技术上可以与Hyper-V 2012R2一起使用,以提供虚拟图形功能。
您将需要主机中的其他图形适配器来安装您的操作系统,您仍然需要在vPC版级别上为每个正在运行的VM获取许可证。
获得这些许可证并因此访问许可证门户后,您就可以下载适用于Windows驱动程序的GRID。
评估许可证是可用的btw。
随着即将发布的Server 2016,Nvidia计划支持Tesla M60,M6和新推出的DDA M10主板。
自Server 2016 TP4以来,此功能已可用于试用,因此使用与上述相同的驱动程序,您可以测试该功能。
如果您有M60卡并需要评估许可证,可以在此处申请:
http://www.nvidia.com/object/grid-evaluation.html
以上来自于谷歌翻译
以下为原文
Rachel's information is absolutely accurate.
RemoteFX virtual graphics adapter uses an API interception mechanism that translates API calls from the Microsoft driver in the guest VM and passes those calls to the hardware driver in the Hyper-V host.
What you see with the K2 is the Microsoft driver intercepting and translating those API calls and passing them to the Nvidia driver in the Hyper-V host.
It's also worth noting a couple of things
The Remote FX virtual graphics adapter is only enabled in fully featured RemoteFX sessions, any other connection method disables it.
It's also limited to DirectX, OpenGL is not supported in the 2012R2 release ( Server 2016 does though). So I'm surprised you're seeing Solidworks use the GPU (it may be running on CPU at a very low feature level).
Anyhow, you asked about M60 support for Hyper-V.
In the case of the M60 there is currently no official support for bare metal deployments, which this type of installation is becasue it's installed into Server 2012R2 (no support for core services, you must have the GUI).
There are several reasons for this which may change in the future.
However, if you're happy testing out an unsupported feature, the Tesla M60 can technically be used with Hyper-V 2012R2 to deliver the virtual graphic functionality. You will need an additional graphics adapter in the host to install your OS and you will still require a license for each running VM at the level of vPC Edition. Once you have these licenses and hence access to the license portal you will be able to download the GRID for Windows drivers. Evaluation licenses are available btw.
With the upcoming release of Server 2016 Nvidia plans to support Tesla M60, M6 and the newly announced M10 boards for DDA. This feature has been available for trial since Server 2016 TP4, so with the same drivers as above you can test the functionality.
If you have an M60 card and require evaluation licenses, you can request them here:
雷切尔的信息绝对准确。
值得注意的还有几点
有几个原因可能会在未来发生变化。
评估许可证是可用的btw。
以上来自于谷歌翻译
以下为原文
