大家好,AcquirePowerReadingsEx方法的同步arg允许您在PNA执行采集时继续执行。
但是,我不知道收购何时结束? 有没有人知道一种方法来判断源功率校准何时结束? 谢谢你的帮助,安迪 以上来自于谷歌翻译 以下为原文 Hi All, The sync arg of the AcquirePowerReadingsEx method allows you to continue execution while the acquisition is performed by the PNA. However I can't tell when the acquisition is ended? Does anyone know of a way to tell when the source power cal sweep has ended? Thanks for your help, Andy |
由于您使用的是COM接口,因此了解异步方法何时完成的唯一方法是启用事件。
但是,我的猜测是你正在使用DCOM(在PC而不是PNA本身上运行你的程序)并且让事件在DCOM上正常工作是非常困难的(你可以感谢微软)。 在COM中使用此命令的异步版本的唯一原因是,如果您的电源获取时间长于默认DCOM超时(通常为6分钟) 以上来自于谷歌翻译 以下为原文 since you are using the COM interface, the only way to know when the asynchronous method has completed is to enable events. However, my guess is that you are using DCOM (running your program on a PC rather than the PNA itself) and getting events to work properly over DCOM is notoriously difficult (you can thank Microsoft for that). the only reason to use the async version of this command in COM is if your power acquisition is longer than the default DCOM timeout (usually 6 minutes) |
Topcbpcba 发表于 2018-11-2 11:17 此外,当您在COM中使用该命令的异步版本时,当您在SourcePowerCalibrator上调用ApplyPowerCorrectionValuesEx(或取代的ApplyPowerCorrectionValues)时,应用功率校正值的调用将 - 正如人们逻辑预期的那样 - 等待 /阻止采集完成,如果它仍在进行中,然后计算修正并返回。 以上来自于谷歌翻译 以下为原文 Also, when you use the asynchronous version of that command in COM, when you do go to call ApplyPowerCorrectionValuesEx (or the superseded ApplyPowerCorrectionValues) on the SourcePowerCalibrator, that call to apply the power correction values will -- as one would logically expect -- wait/block on the acquisition to complete if it is still in-progress and then computes the correction and returns. |
1311 浏览 0 评论
2385 浏览 1 评论
2203 浏览 1 评论
2079 浏览 5 评论
2963 浏览 3 评论
1180浏览 1评论
767浏览 0评论
982浏览 0评论
1312浏览 0评论
GMT+8, 2025-1-4 17:47 , Processed in 1.718829 second(s), Total 78, Slave 62 queries .
