电子发烧友william hill官网
你好
我尝试使用xilinx 7系列收发器IP生成器示例(Vivdao提供) Thegt0_qplllock_in,gt0_qplloutclk_in,gt0_qplloutrefclk_in和gt0_qpllrefclklost_in信号仅用于提供GTXE2_COMMON? 以上来自于谷歌翻译 以下为原文 Hello I'am try to used xilinx 7-series transciever IP to generator example(Vivdao provide) The gt0_qplllock_in, gt0_qplloutclk_in, gt0_qplloutrefclk_in and gt0_qpllrefclklost_in signals only used GTXE2_COMMON provide? |
3个回答
可以引用此问题:
https://forums.xilinx.com/t5/Implementation/Virtex7-GTX-transcievers-issue/td-p/749223 在原帖中查看解决方案 以上来自于谷歌翻译 以下为原文 This issue can be referenced : https://forums.xilinx.com/t5/Implementation/Virtex7-GTX-transcievers-issue/td-p/749223 View solution in original post |
你好@ quincyq2003,
你能详细说明一下你的问题吗? 你在寻找什么细节? 问候,阿希什----------------------------------------------- - - - - - - - - - - - - - - - - - - - - - - - -请注意- 如果提供的信息有用,请将答案标记为“接受为解决方案”。给予您认为有用且回复的帖子。感谢Kudos .-------------------- -------------------------------------------------- ------------------------ 以上来自于谷歌翻译 以下为原文 Hello @quincyq2003, Can you please elaborate your question? What are the details you are looking for? Regards, Ashish ---------------------------------------------------------------------------------------------- Kindly note- Please mark the Answer as "Accept as solution" if information provided is helpful. Give Kudos to a post which you think is helpful and reply oriented. ---------------------------------------------------------------------------------------------- |
可以引用此问题:
https://forums.xilinx.com/t5/Implementation/Virtex7-GTX-transcievers-issue/td-p/749223 以上来自于谷歌翻译 以下为原文 This issue can be referenced : https://forums.xilinx.com/t5/Implementation/Virtex7-GTX-transcievers-issue/td-p/749223 |
2427 浏览 7 评论
2828 浏览 4 评论
2295 浏览 9 评论
3377 浏览 0 评论
2467 浏览 15 评论
1262浏览 1评论
591浏览 1评论
455浏览 1评论
2009浏览 0评论
735浏览 0评论
GMT+8, 2024-12-26 03:47 , Processed in 1.363739 second(s), Total 82, Slave 66 queries .
