嗨,大家好,
如果您能帮助我对林立模式的运作有一个清晰的了解,我将不胜感激。根据我的理解,总线空闲情况发生(没有LIN流量4-10秒),或者从主机接收到的睡眠命令,LIN PHY将进入待机模式。 请帮助我了解LIN PHY的状态,对于下面的场景, A)ECU通电,在ECU上电后4-10秒没有LIN流量,LIN PHY的状态是什么?正常模式或待机模式 b)ECU被加电,并且至少一个LIN帧通过总线传输,并且没有4-10秒的流量,LIN PHY的状态是什么?正常模式或待机模式 希望你在场景A和B之间有所不同。 谢谢, 维沙克J 以上来自于百度翻译 以下为原文 Hi All, It will be grateful if you can help me with a clear understanding of LIN stand by mode operation. As per my understanding, Bus Idle situation happens(no LIN traffic for 4-10seconds), or go-to sleep command received from master, the LIN PHY will go for stand-by mode. Please help me with the state of LIN PHY, for the below mentioned scenario, a) The ECU is powered up and there is no LIN traffic for 4-10seconds after powering up the ECU, what will be state of LIN PHY? : Normal mode or Standby mode b) The ECU is powered up, and at least one LIN frame is transmitted through the bus, and there is no traffic for 4-10seconds, what will be state of LIN PHY? : Normal mode or Standby mode Hope you got the difference between scenario a and b. Thanks , Vyshakh J |
嗨,Vyshakh,
在上述两种情况下,林菲都将进入待命状态。 你可以参考下面的LIN规范的“2.63.入睡”部分: HTTPS://www. CS-GROUP.DE/WP CONTRON/XOPADS/2016/11/LIN SubjiTuxPayaGe2.2.2A.PDF 请随时更新任何查询。 当做 哈尔沙塔 以上来自于百度翻译 以下为原文 Hi Vyshakh, In both the above LINPHY will go to stand by mode. You can refer the section '2.6.3 GO TO SLEEP' of LIN spec below: https://www.cs-group.de/wp-content/uploads/2016/11/LIN_Specification_Package_2.2A.pdf Please feel free to update for any query. Regards Harshada |
756个成员聚集在这个小组
加入小组2121 浏览 1 评论
1864 浏览 1 评论
3680 浏览 1 评论
1799 浏览 6 评论
1542 浏览 1 评论
589浏览 2评论
439浏览 2评论
446浏览 2评论
395浏览 2评论
1057浏览 2评论
GMT+8, 2025-1-3 06:20 , Processed in 0.954143 second(s), Total 76, Slave 60 queries .
