电子发烧友william hill官网
嗨,
我们为Vivado 14.2购买了激活基础许可证。 我从xilinx网站下载它,并通过VivadoManege License.Bu将它设置到我的电脑。现在我想使用ISE Design Suite 14.7,我的问题来自这里。 据我所知,我可以使用ISE的vivado许可证。 我还没试过。但是对于模拟,Thevivado授权不适用于ISim.It给出以下警告。 我可以为Isim使用vivado许可证吗? 如果答案是肯定的,我该如何使用许可证运行Isim? 提前致谢。 警告:找到了WEBPACK许可证。 警告:请使用Xilinx许可证配置管理器查看完整的ISim许可证。 警告:ISim将以精简模式运行。 有关Lite和完整版之间差异的更多信息,请参阅ISim文档。 最好的祝福, Fatih Temizkan 以上来自于谷歌翻译 以下为原文 Hi, We bought activation base license for Vivado 14.2. I download it from xilinx site, and set it to my computer via Vivado Manege License. Bu now I want to use ISE Design Suite 14.7, And my question cames from here. As I know, I can use vivado licence for ISE. I have not tried it yet. But for simulation, The vivado license does not work for ISim. It gives the following Warnings. May I use vivado license for Isim? If the answer is yes, what should I do to run Isim with the licence? Thanks in advance. WARNING: A WEBPACK license was found. WARNING: Please use Xilinx License Configuration Manager to check out a full ISim license. WARNING: ISim will run in Lite mode. Please refer to the ISim documentation for more information on the differences between the Lite and the Full version. Best regards, Fatih Temizkan |
6个回答
嗨,
您需要从xilinx许可帐户下载ISE的.lic文件。 您可以在基于证书的许可证部分找到它。 在原帖中查看解决方案 以上来自于谷歌翻译 以下为原文 Hi, You need to download the .lic file for ISE from your xilinx licensing account. You can find it under certificate based licenses section. View solution in original post |
嗨,你为IS安装了.lic吗?
请附上许可证文件 谢谢,维杰----------------------------------------------- ---------------------------------------------请将帖子标记为 一个答案“接受为解决方案”,以防它有助于解决您的查询。如果一个帖子引导到解决方案,请给予赞誉。 以上来自于谷歌翻译 以下为原文 Hi, Did you install .lic for IS? Please attach the license fileThanks,Vijay -------------------------------------------------------------------------------------------- Please mark the post as an answer "Accept as solution" in case it helped resolve your query. Give kudos in case a post in case it guided to the solution. |
嗨,
您需要安装.lic许可证才能使用ISE 14.7及更早版本。 从Vivado 2014.1开始,ISE和Vivado许可权利分开。 Vivado使用新的基于激活的许可证,该许可证与ISE不兼容。 您将获得购买新Vivado的ISE许可证。 换句话说,2014.1发布后的工具购买将获得: - 用于使用viavdo工具的Vivado(.xml文件)的激活权利 - ISE的单独证书(.licfile)权利 从您的许可帐户,您需要从基于证书的lciensings ection生成.lic许可证,并且无法正确使用ISE。 以上来自于谷歌翻译 以下为原文 Hi, You need to install .lic license to use ISE 14.7 and earlier versions. Starting in Vivado 2014.1, ISE and Vivado licensing entitlements were separated. Vivado uses new activation based license, which is not compatible with ISE. You will get an ISE license with a new Vivado purchase. In other words, tool purchases after 2014.1 launch will receive: –An Activation entitlement for Vivado(.xml file) to use with viavdo tools–A separate Certificate (.lic file) entitlement for ISE From your licensing account you need to generate the .lic license from certificate based lciensings ection and isntall it properly to use ISE. |
我有web包的.lic文件。我们的getactivation基本许可证,蚂蚁是.xml文件,athached。
法提赫 Xilinx_License.xml 3 KB 以上来自于谷歌翻译 以下为原文 I just have .lic file for webpack . We got activation base licence, ant it is .xml file that athached. Fatih |
嗨,
您需要从xilinx许可帐户下载ISE的.lic文件。 您可以在基于证书的许可证部分找到它。 以上来自于谷歌翻译 以下为原文 Hi, You need to download the .lic file for ISE from your xilinx licensing account. You can find it under certificate based licenses section. |
非常感谢您的快速帮助。
我错过了ISE网站上的.lic文件。 现在问题解决了。 最好的祝福, Fatrih Temizkan 以上来自于谷歌翻译 以下为原文 Thank you very much for your quick help. I missed .lic file that been on web site for ISE. Now problem is solved. Best regards, Fatrih Temizkan |
2427 浏览 7 评论
2828 浏览 4 评论
2295 浏览 9 评论
3377 浏览 0 评论
2467 浏览 15 评论
1264浏览 1评论
591浏览 1评论
455浏览 1评论
2009浏览 0评论
735浏览 0评论
GMT+8, 2024-12-26 05:14 , Processed in 1.613457 second(s), Total 85, Slave 69 queries .
