扫一扫,分享给好友
我正在使用Vivado 2015.4与Windows 10操作系统一起工作。
直到今天早上,这工作还算不错。 现在我得到以下综合错误: [Common 17-345]找不到功能'Synthesis'和/或设备'xc7z020'的有效许可证。 请运行Vivado许可证管理器以获取有关确定哪些功能和设备已获得系统许可的帮助。解决方案:在Vivado许可证管理器中检查许可证的状态。 对于调试帮助,请搜索Xilinx支持“许可常见问题解答”。 之后我检查了我的许可证状态,但我找不到任何不寻常的东西。 这有点奇怪! 谢谢 以上来自于谷歌翻译 以下为原文 I am working as mentioned with Vivado 2015.4 with windows 10 operational system. That was working pretty good till today morning. Now i am getting the following synthesis error : [Common 17-345] A valid license was not found for feature 'Synthesis' and/or device 'xc7z020'. Please run the Vivado License Manager for assistance in determining which features and devices are licensed for your system. Resolution: Check the status of your licenses in the Vivado License Manager. For debug help search Xilinx Support for "Licensing FAQ". After that I checked my license status, but i could not find any unusual thing. That is a little bit strange! Thank you |
10个回答
@michielbosch
您拥有的许可证特定于XC7VX485T。 webpack许可证支持Asxc7z020,您可以登录以下链接并生成vivado webpack许可证以使用此设备: http://www.xilinx.com/getlicense --Syed -------------------------------------------------- -------------------------------------------请注意 - 请标记答案 如果提供的信息有用,请“接受为解决方案”。给予您认为有用并回复导向的帖子。感谢Kudos .------------------------ -------------------------------------------------- ------------------- 在原帖中查看解决方案 以上来自于谷歌翻译 以下为原文 @michielbosch The license you have is specific to XC7VX485T. As xc7z020 is supported with webpack license, You can log in in below link and generate vivado webpack license to use this device : http://www.xilinx.com/getlicense --Syed --------------------------------------------------------------------------------------------- Kindly note- Please mark the Answer as "Accept as solution" if information provided is helpful. Give Kudos to a post which you think is helpful and reply oriented. ---------------------------------------------------------------------------------------------View solution in original post |
@michielbosch
从Vivado TCL控制台运行以下命令以生成xinfo.txt。 report_environment -file xinfo.txt 运行该命令后,只需键入“pwd”,这将显示生成xinfo.txt文件的路径。 您可以浏览到该路径并找到该文件。 --Syed -------------------------------------------------- -------------------------------------------请注意 - 请标记答案 如果提供的信息有用,请“接受为解决方案”。给予您认为有用并回复导向的帖子。感谢Kudos .------------------------ -------------------------------------------------- ------------------- 以上来自于谷歌翻译 以下为原文 @michielbosch Run the following command from Vivado TCL console to generate xinfo.txt. report_environment -file xinfo.txt After running the command just type “pwd” this will show you the path where the xinfo.txt file is generated. You can browse to that path and find the file. --Syed --------------------------------------------------------------------------------------------- Kindly note- Please mark the Answer as "Accept as solution" if information provided is helpful. Give Kudos to a post which you think is helpful and reply oriented. --------------------------------------------------------------------------------------------- |
我不了解整个信息。
我需要专门的帮助来解决这个问题。 因为我没有时间,因为我的项目将在两天内结束,现在这种错误:-(! 以上来自于谷歌翻译 以下为原文 I am not understanding the entire information. I need dedicated help to solve this problem. Because i have no more time, since my project will end in two days and now this kind of error :-( ! |
@michielbosch
哎呀! 我的错。 你能否使用我上一篇文章中提到的命令生成xinfo.txt文件,并共享生成的xinfo.txt文件来调试问题。 --Syed -------------------------------------------------- -------------------------------------------请注意 - 请标记答案 如果提供的信息有用,请“接受为解决方案”。给予您认为有用并回复导向的帖子。感谢Kudos .------------------------ -------------------------------------------------- ------------------- 以上来自于谷歌翻译 以下为原文 @michielbosch Oops! My mistake. Can you please generate the xinfo.txt file using the command mentioned in my previous post and share the generated xinfo.txt file to debug the issue. --Syed --------------------------------------------------------------------------------------------- Kindly note- Please mark the Answer as "Accept as solution" if information provided is helpful. Give Kudos to a post which you think is helpful and reply oriented. --------------------------------------------------------------------------------------------- |
我有VC707许可证,这个许可证包括Zedboar XC7z020 FPGA吗?
以上来自于谷歌翻译 以下为原文 I have VC707 License, did this license include Zedboar XC7z020 FPGA ? |
@michielbosch
该许可证不是特定于该设备的,并且不能与XC7Z020一起使用。 但是,从您共享的快照中我看到您拥有支持XCZ020设备的validwebpack许可证。 https://www.xilinx.com/support/documentation/sw_manuals/xilinx2015_4/ug973-vivado-release-notes-install-license.pdf#page=15 然而,webpack许可证似乎是ISE而不是Vivado。 因此,您在vivado中看到许可证错误。 --Syed -------------------------------------------------- -------------------------------------------请注意 - 请标记答案 如果提供的信息有用,请“接受为解决方案”。给予您认为有用并回复导向的帖子。感谢Kudos .------------------------ -------------------------------------------------- ------------------- 以上来自于谷歌翻译 以下为原文 @michielbosch No that license is specific to the device and it cannot be used with XC7Z020. However, from the snapshot you shared I see that you have valid webpack license which does support XCZ020 device. https://www.xilinx.com/support/documentation/sw_manuals/xilinx2015_4/ug973-vivado-release-notes-install-license.pdf#page=15 However the webpack license seems to be of ISE and not Vivado. Hence you are seeing the license error in vivado. --Syed --------------------------------------------------------------------------------------------- Kindly note- Please mark the Answer as "Accept as solution" if information provided is helpful. Give Kudos to a post which you think is helpful and reply oriented. --------------------------------------------------------------------------------------------- |
@michielbosch
您拥有的许可证特定于XC7VX485T。 webpack许可证支持Asxc7z020,您可以登录以下链接并生成vivado webpack许可证以使用此设备: http://www.xilinx.com/getlicense --Syed -------------------------------------------------- -------------------------------------------请注意 - 请标记答案 如果提供的信息有用,请“接受为解决方案”。给予您认为有用并回复导向的帖子。感谢Kudos .------------------------ -------------------------------------------------- ------------------- 以上来自于谷歌翻译 以下为原文 @michielbosch The license you have is specific to XC7VX485T. As xc7z020 is supported with webpack license, You can log in in below link and generate vivado webpack license to use this device : http://www.xilinx.com/getlicense --Syed --------------------------------------------------------------------------------------------- Kindly note- Please mark the Answer as "Accept as solution" if information provided is helpful. Give Kudos to a post which you think is helpful and reply oriented. --------------------------------------------------------------------------------------------- |
现在许可证服务器工作不顺利,明天我将恢复工作。
谢谢syedz。 以上来自于谷歌翻译 以下为原文 Now the License server is not working very well, I will resume my work tomorrow. Thank you syedz. |
2436 浏览 7 评论
2833 浏览 4 评论
2303 浏览 9 评论
3383 浏览 0 评论
2479 浏览 15 评论
1511浏览 1评论
603浏览 1评论
468浏览 1评论
2019浏览 0评论
743浏览 0评论
GMT+8, 2025-1-3 04:48 , Processed in 1.676772 second(s), Total 63, Slave 57 queries .
