>>但是,输出与我的观察略有不同。你需要更具体地了解你的预期和观察结果,以便可以做出更详细的反应,但一般来说观察系统可能会改变它的行为:-)特别是
在您的情况下,添加观察点可能会阻止综合工具进行一些优化并为合成输出添加更多逻辑。
- 如果提供的信息有用,请将答案标记为“接受为解决方案”。给予您认为有用且回复的帖子。
以上来自于谷歌翻译
以下为原文
>> However, the output is slightly different from my observation.
you need to be more specific as to what you expected and observed so that a more detailed response can be made but in general observing a system may change its behavior :-)
Specifically in your case, it is possible that adding an observation point is preventing the synthesis tool making some optimizations and adding more logic to the synthesized output.- Please mark the Answer as "Accept as solution" if information provided is helpful.
Give Kudos to a post which you think is helpful and reply oriented.
以上来自于谷歌翻译
以下为原文
