电子发烧友william hill官网
我是一个新手。在sp601板上编程FPGA的可行方法是什么?
我没有连接FMC连接器。 如果有人能提供帮助,我将不胜感激 以上来自于谷歌翻译 以下为原文 I m a Newbie.What are the possible ways of programming fpga on sp601 board? I do not have FMC connector attached. Would appreciate if some one can help. |
4个回答
您是否阅读了SP601硬件用户指南中的configuarion选项部分?
------您是否尝试在Google中输入问题? 如果没有,你应该在发布之前。太多结果? 尝试添加网站:www.xilinx.com 以上来自于谷歌翻译 以下为原文 Have you read the configuarion options section in the SP601 Hardware User Guide? ------Have you tried typing your question into Google? If not you should before posting. Too many results? Try adding site:www.xilinx.com |
是。
我确实知道了。 感谢您的答复。 我可以直接编程fpga但是我如何编程spi flash(todo永久编程)? 我应该创建一个影响力的舞会文件,并下载位图文件? 以上来自于谷歌翻译 以下为原文 Yes. I did know. Thank you for the reply. I am able to program the fpga directly but how do i program spi flash ( to do permanent programming) ? Should i create a prom file in impact and download it with the bit map file? |
首先在iMPACT中创建一个prom文件(通常是一个MCS)然后你可以间接地将这个文件编程到SPI flash中。
请阅读UG332中的“准备SPI prom文件”和“使用iMPACT进行间接SPI编程”: http://www.xilinx.com/support/documentation/user_guides/ug332.pdf S3A有分步说明,但也适用于S6。 -------------------------------------------------- -------------------------------------------------- --------不要忘记回复,kudo,并接受为解决方案.---------------------------- -------------------------------------------------- --------------------------- 以上来自于谷歌翻译 以下为原文 You first create a prom file (usually a MCS) in iMPACT and then you can indirectly program this file into the SPI flash. Please read 'Prepare an SPI prom file' and 'Indirect SPI programming using iMPACT' in UG332: http://www.xilinx.com/support/documentation/user_guides/ug332.pdf There are step by step instructions for S3A but applicable to S6 as well. ------------------------------------------------------------------------------------------------------------ Don't forget to reply, kudo, and accept as solution. --------------------------------------------------------------------------------------------------------- |
2427 浏览 7 评论
2828 浏览 4 评论
2295 浏览 9 评论
3377 浏览 0 评论
2467 浏览 15 评论
1266浏览 1评论
591浏览 1评论
455浏览 1评论
2009浏览 0评论
735浏览 0评论
GMT+8, 2024-12-26 05:59 , Processed in 1.135736 second(s), Total 51, Slave 45 queries .
