电子发烧友william hill官网
嗨,
我想开发一个基于Spartan-6的定制FPGA板,只需FPGA,DDR2 RAM,JTAG和GPIO。 稍后我想添加一个RF前端来实现软件定义的无线电。 Xilinx是否有一个程序来帮助个人(而非公司)开发定制板? 例如 技术支持,早期采用者支持,访问样本芯片等? 最好的祝福, 埃尔维斯·道森 以上来自于谷歌翻译 以下为原文 Hi, I would like to develop a custom Spartan-6 based FPGA board, with just the FPGA, DDR2 RAM, JTAG and GPIOs. Later on I would like to add an RF front end to implement a software defined radio. Does Xilinx have a program to assist individuals (not companies) develop custom boards? e.g. tech support, early adopter support, access to sample chips, etc? Best regards, Elvis Dowson |
elvisjohndowson写道:
Xilinx是否有一个程序来帮助个人(而非公司)开发定制板? 例如 技术支持,早期采用者支持,访问样本芯片等? 围绕这些部分,我们将“定制板”称为“我们的产品”。 评估板,数据表,用户手册等都足以让您入门。 技术支持和样品通常可以通过您当地的FAE获得,如果您要将头撞在墙上,可以打开WebCase。 ----------------------------是的,我这样做是为了谋生。 以上来自于谷歌翻译 以下为原文 elvisjohndowson wrote: Around these parts, we call "custom boards" "our products." The eval boards, data sheets, user manuals and such are all sufficient to get you started. Tech support and samples are generally available through your local FAE, and if you're into bashing your head against a wall, you can open a WebCase. ----------------------------Yes, I do this for a living. |
2427 浏览 7 评论
2828 浏览 4 评论
2295 浏览 9 评论
3377 浏览 0 评论
2467 浏览 15 评论
1266浏览 1评论
591浏览 1评论
455浏览 1评论
2009浏览 0评论
735浏览 0评论
GMT+8, 2024-12-26 05:58 , Processed in 1.135573 second(s), Total 77, Slave 61 queries .
