嗨,
我想知道是否有关于它们之间技术文档 Spartan-6 XC6SLX25 FTG256A 和 Spartan-6 XC6SLX25 FTG256B 看起来,差异是芯片修订版(A和B),但我没有找到任何技术文档,勘误表或其他相关内容。 我感谢任何帮助。 最好的祝福。 Joesny。 以上来自于谷歌翻译 以下为原文 Hi, I would like to know if there any technical documentation about the differences between Spartan-6 XC6SLX25 FTG256A and Spartan-6 XC6SLX25 FTG256B Looks like, that the differences are the silicon revisions (A and B), but I didn't found any technical documentation, errata or something about this. I appreciate any help. Best Regards. Joesny. |
Joesny,
联系您的Xilinx分销商。 对我来说听起来并不像硅片有任何不同:A,B在包装标识符上,而不是模具部件号。 Silcon版本受到严格控制:有ES,一般ES和生产(步进)。 ES是尚未完全表征的初始silcon,并且已在线列出勘误表。 当我们完成表征时,一般ES就在生产之前,并且可能是也可能不是来自ES的新掩模集(通常不是,只是一个或两个层'修复'的一些小错误)。 生产有步骤(修订)也在线完整记录。 如果您没有找到任何转换(步进),那么符号可能指的是包装差异。 或者,它可能是一个评论(伪造)部分:不要从授权经销商以外的任何人那里购买! Austin Lesea主要工程师Xilinx San Jose 以上来自于谷歌翻译 以下为原文 Joesny, Contact your Xilinx distributor. It doesn't sound to me like there is any difference in the silicon: The A, B is on the package designator, not the die part number. Silcon revision are very tightly controlled: there is ES, general ES, and production (steppings). ES is the intial silcon that has not been fully characterized, and has errata listed on line. general ES is just prior to production when we are finishing the characterization, and may or may not be a new mask set from ES (often not, just a one or two layer 'fix' of some small bug). Production has steppings (revisions) also fully documented on line. If you are not finding any revsions (steppings) then the notation may refer to a packaging difference. Or, it could be a remarked (counterfeit) part: DO NOT BUY FROM ANYONE OTHER THAN AN AUTHORIZED DISTRIBUTOR! Austin Lesea Principal Engineer Xilinx San Jose |
有关此掩码更改的详细信息,请参阅http://www.xilinx.com/support/documentation/customer_notices/xcn11012.pdf上的客户通知。
以上来自于谷歌翻译 以下为原文 Refer to the customer notice at http://www.xilinx.com/support/documentation/customer_notices/xcn11012.pdf for details on this mask change. |
2427 浏览 7 评论
2828 浏览 4 评论
2295 浏览 9 评论
3377 浏览 0 评论
2467 浏览 15 评论
1266浏览 1评论
591浏览 1评论
455浏览 1评论
2009浏览 0评论
735浏览 0评论
GMT+8, 2024-12-26 05:52 , Processed in 1.420486 second(s), Total 80, Slave 64 queries .
