在cy7c2564xv18 datasheet,Idd被指定为百分之五十的读写周期的一半(注24页)。
的QDRII +具有读写专用的接口,可以把它推到100%读100%写周期。那么,核心权力会发生什么变化呢?国际长途电话双倍吗? 问题在于使用率较低。IDD在10%预计什么? 当做, 弗里德里克 以上来自于百度翻译 以下为原文 In CY7C2564XV18 datasheet, Idd is specified for 50% read and 50% write cycles (note 24 on p.20). The QDRII+ having dedicated interfaces for read and write, one can push it to 100% read and 100% write cycles. Then, what happens to the core power? Does Idd double? Question holds for lower usage. What Idd to expect at 10%? Regards, Frederic |
你好,
QDR - II型+记忆可以执行读写操作在并行但内部存储单元可以执行一个操作(读或写)的时候。所以我们考虑最坏的情况是50的内部存储阵列读写50分。 赛普拉斯并未指定基于不同的读写操作和IDD值比有一个与其相关的分布。然而,我们专注于最坏的情况(Idd max)这样才能保证Idd(max)值。 谢谢, 普里茨 以上来自于百度翻译 以下为原文 Hi, QDR-II+ memories can perform read and write operation in parallel but internally memory cell can execute a single operation (Read or Write) at the time. So we are considering the worst case which is 50% read and 50% write for internal memory array. Cypress does not specify Idd values based on different reads and writes operation ratio as there is a distribution associated with the same. However, we focus on the worst case situation (Idd max) so that we can guarantee Idd (MAX) values. Thanks, Pritesh |
我知道注释24中指定的50-50%用法与内部存储器操作有关,而不是与它的外部接口有关。
我将考虑为Idd指定的值作为最坏的可能消耗。 谢谢你的快速回答。 弗里德里克 以上来自于百度翻译 以下为原文 I understand that 50-50% usage specified in note 24 is related to the internal memory operation, not to its external interfaces. I'll consider the values specified for Idd as the worst possible consumption. Thanks for that quick answer. Frederic |
756个成员聚集在这个小组
加入小组2121 浏览 1 评论
1864 浏览 1 评论
3680 浏览 1 评论
1799 浏览 6 评论
1543 浏览 1 评论
592浏览 2评论
440浏览 2评论
447浏览 2评论
399浏览 2评论
1058浏览 2评论
GMT+8, 2025-1-4 06:20 , Processed in 1.007472 second(s), Total 80, Slave 64 queries .
