基本设置
串口回环: 串口IO设置 IO的配置: void gd_eval_com_init(uint32_t com) { /* enable GPIO clock */ uint32_t COM_ID; if(EVAL_COM1 == com) { COM_ID = 0U; } rcu_periph_clock_enable( EVAL_COM_GPIO_CLK); /* enable USART clock */ rcu_periph_clock_enable(COM_CLK[COM_ID]); /* connect port to USARTx_Tx */ gpio_af_set(EVAL_COM_GPIO_PORT, EVAL_COM_AF, COM_TX_PIN[COM_ID]); /* connect port to USARTx_Rx */ gpio_af_set(EVAL_COM_GPIO_PORT, EVAL_COM_AF, COM_RX_PIN[COM_ID]); /* configure USART Tx as alternate function push-pull */ gpio_mode_set(EVAL_COM_GPIO_PORT, GPIO_MODE_AF, GPIO_PUPD_PULLUP,COM_TX_PIN[COM_ID]); gpio_output_options_set(EVAL_COM_GPIO_PORT, GPIO_OTYPE_PP, GPIO_OSPEED_50MHZ,COM_TX_PIN[COM_ID]); /* configure USART Rx as alternate function push-pull */ gpio_mode_set(EVAL_COM_GPIO_PORT, GPIO_MODE_AF, GPIO_PUPD_PULLUP,COM_RX_PIN[COM_ID]); gpio_output_options_set(EVAL_COM_GPIO_PORT, GPIO_OTYPE_PP, GPIO_OSPEED_50MHZ,COM_RX_PIN[COM_ID]); /* USART configure */ usart_deinit(com); usart_baudrate_set(com,115200U); usart_receive_config(com, USART_RECEIVE_ENABLE); usart_transmit_config(com, USART_TRANSMIT_ENABLE); usart_enable(com); nvic_irq_enable(USART1_IRQn, 0, 0); } 配置的是COM1; PA2 —TX ; PA3 — RX; 串口1 PA9、PA10不知道为什么实现不了;在GD32450Demo板上实现不了; 接收设置 接收可中断接收、也可以论询接收; 中断接收 注意在中断中接收的话: 要打开NVIC并设置USART1的优先级; nvic_irq_enable(USART1_IRQn, 0, 0); 基本配置 : 设置能发送、能接收; 波特率、停止位; 中断接收: 接收重点是要打开串口函数: 一旦有数据就会有串口中断, usart_interrupt_enable(USART1 , USART_INTEN_RBNEIE); 然后在中断中接收: void USART1_IRQHandler(void) { unsigned char data; if(RESET != usart_interrupt_flag_get(USART1, USART_INT_RBNEIE)) { data = usart_data_receive(USART1); usart_data_transmit(USART1, (uint8_t)data); while(RESET == usart_flag_get(USART1, USART_FLAG_TBE)); } } 接收又回复之后立马回复、完成回环测试;; 论询接收 就是不打开中断 要在程序中论询: 一直查询接收buff是否是为空状态; if(RESET != usart_interrupt_flag_get(USART1, USART_INT_RBNEIE)) { data = usart_data_receive(USART1); usart_data_transmit(USART1, (uint8_t)data); while(RESET == usart_flag_get(USART1, USART_FLAG_TBE)); } |
1739 浏览 0 评论
3339 浏览 9 评论
3017 浏览 16 评论
3508 浏览 1 评论
9106 浏览 16 评论
1224浏览 3评论
633浏览 2评论
621浏览 2评论
2363浏览 2评论
1928浏览 2评论
GMT+8, 2025-1-14 15:14 , Processed in 1.467488 second(s), Total 77, Slave 58 queries .
