我一直在努力为 i.MX 8M nano添加Rust支持,并设法让威廉希尔官方网站
板与工作的 uart 驱动程序一起启动和运行 - 代码在这里
我计划的下一步是为 nano 添加一个 uSDHC 驱动程序。这是初始实现的链接 该实施不断抛出一些 i.MX 特定的 uSDHC命令错误。我希望这里有人可以对此有所了解。 我使用的步骤顺序如下
这是调试日志输出。从我通过查看 uSDHC 的中断状态字段的内容(即值0x00048001)收集到的信息,命令(即 SEND_IF_CMD)已成功发送并收到响应,但是返回的响应包含错误 -命令结束位错误. 不完全确定为什么会这样。 当前状态寄存器还设置了 SDOFF 位(SD 时钟在内部关闭)。再次不确定为什么会这样。参考手册不提供有关这些位或错误的更多信息。 任何输入将不胜感激。如果需要更多信息,请告诉我。 [ 0.000004] imx8mn-rs version 0.1.0 [ 0.003516] Booting on: i.MX 8M Nano EVK [ 0.007340] Current privilege level: EL3 [ 0.011254] Exception handling state: [ 0.014966] Debug: Masked [ 0.018166] SError: Unmasked [ 0.021464] IRQ: Masked [ 0.024758] FIQ: Masked [ 0.027968] Drivers loaded: [ 0.030739] 1. i.MX8M Uart2 [ 0.034045] Chars written: 382 [ 0.036995] Sd host circuit reset.. [ 0.040462] Prescaler = 4, Divisor = 15, Freq Set = 400000 [ 0.045966] Sd: sending command, CMD_NAME: "GO_IDLE_STATE", CMD_CODE: 0x00000000, CMD_ARG: 0x00000000 [ 0.056378] Sd: sending command, CMD_NAME: "SEND_IF_COND", CMD_CODE: 0x08020000, CMD_ARG: 0x000001aa [ 0.066602] Sd Error: Cmd response returned an error, PresentStatus: 0xf0048088, intStatus: 0x00048001, Resp0: 0x00000000, timeDiff: 0 [ 0.078923] Sd host circuit reset.. [ 0.082293] Prescaler = 4, Divisor = 15, Freq Set = 400000 [ 0.087788] Sd: sending command, CMD_NAME: "GO_IDLE_STATE", CMD_CODE: 0x00000000, CMD_ARG: 0x00000000 [ 0.098218] Sd: sending command, CMD_NAME: "APP_CMD", CMD_CODE: 0x17000000, CMD_ARG: 0x00000000 [ 0.108176] Sd: sending command, CMD_NAME: "APP_SEND_OP_COND", CMD_CODE: 0x09020000, CMD_ARG: 0x00ff8000 [ 0.119630] Sd Error: Cmd response returned an error, PresentStatus: 0xf0048088, intStatus: 0x00048001, Resp0: 0x00000000, timeDiff: 0 [ 0.131839] Sd Error: ACMD41 returned non-timeout error SdError [ 0.137829] uSDHC: PRES_STATE: 0xf0048088, SYS_CTRL: 0x000e02e0, INT_STATUS: 0x00048001 [ 0.146063] uSDHC: CMD "APP_SEND_OP_COND", resp: SdError, CMD_RSP3: 0x00000000, CMD_RSP2: 0x00000000, CMD_RSP1: 0x00000000, CMD_RSP0: 0x00000000 [ 0.159382] failed to initialize [ 0.162494] [ 0.164107] ... wait forever |
1951个成员聚集在这个小组
36514 浏览 0 评论
5836 浏览 1 评论
6185 浏览 1 评论
6884 浏览 0 评论
4294 浏览 0 评论
696浏览 2评论
675浏览 2评论
687浏览 2评论
766浏览 2评论
894浏览 2评论
GMT+8, 2025-1-28 15:42 , Processed in 1.091139 second(s), Total 73, Slave 57 queries .
