Hi-FRDS
什么样的传感器可以用来测量速度? 哪种传感器最适合测量速度?为什么? 邮寄一些资料 以上来自于百度翻译 以下为原文 hi frds what type of sensors available for measuring speed? which sensors are best for measuring speed?why? post some materials |
12个回答
哎呀,这必须更精确一些:
飞机TAS?测量压力、温度 船舶(日志)-G.日志脉冲 转速传感器的汽车(转速表)脉冲 自行车每转一个脉冲 液体流量 接近声纳或声呐或微波回波的方法 …等等 以上来自于百度翻译 以下为原文 Whoops, that has to be a bit more precise: Airplane TAS? -> measuring pressure, temperature Ship (Log) -> Pulses from log Car (Tachometer) Pulses from tach-sensor Bicycle -> one pulse per revolution Flux of a liquid Approach to an obstracle -> sonar or microwave echo ... and so on |
你在尝试测量吗?
1)角速度/加速度? 2)线性速度/加速度? 3)你试图测量的目标对象? 4)测量精度? 5)测量分辨率? 6)运动物体? 7)环境条件? 问候,Dana。 以上来自于百度翻译 以下为原文 Are you trying to measure - 1) Angular rotation speed/acceleration ? 2) Linear speed/acceleration ? 3) Target object you are trying to measure ? 4) Accuracy of measurement ? 5) Resolution of measurement ? 6) Object material under motion ? 7) Environmental conditions ? Regards, Dana. |
线性速度在你的名单上,Dana。
下一个问题可能是如何加快速度: 旋转编码器 轴编码/光学 磁线圈 或者… 鲍勃 以上来自于百度翻译 以下为原文 Linear speed was on your list, Dana. Next questions could be how to pick up the speed: Rotattion encoder shaft encoding / optical Magnetic coil or ... Bob |
差分B/W光传感器和红外光耦合器?哪一个是最好的测量rpm & gt;?
以上来自于百度翻译 以下为原文 difference b/w optical sensor and ir optocoupler? which is best for measuring rpm>? |
我们仍然在猜测:你要测量的物体的速度是什么,你期望的转速是多少?
测量是一个固定的组件,还是你正在建造一个手持设备,你想显示RPMS从任何或从特殊表面拾取的接触较少。RPMS是否足够低以固定物体(磁体/反射条纹)? 鲍勃 以上来自于百度翻译 以下为原文 Still we are in a guess: what is the object you're going to measure its speed, what rpm do you expect and is the measurement a fixed assembly or are you building a hand-held device that you want to show rpms picked up contact-less from any or from special surfaces. Are the rpms low enough to fix sometihn to the object (magnet / refection stripe? Bob |
1)角速度/加速度?
2)线性速度/加速度? 3)你试图测量的目标对象? 4)测量精度? 5)测量分辨率? 6)运动物体? 7)环境条件? 问候,Dana。 以上来自于百度翻译 以下为原文 1) Angular rotation speed/acceleration ? 2) Linear speed/acceleration ? 3) Target object you are trying to measure ? 4) Accuracy of measurement ? 5) Resolution of measurement ? 6) Object material under motion ? 7) Environmental conditions ? Regards, Dana. |
我要塞浦路斯给我拿个水晶碗。
微笑的鲍勃 以上来自于百度翻译 以下为原文 I'm going to ask Cypress to get me a crystal bowl. Smiling Bob |
“开槽”光耦合器和光学传感器(通常采用红外LED和光电二极管作为分立器件)是相同的,唯一的区别是开槽光耦合器是单一封装的。为了测量速度,需要记录来自光学传感器的脉冲频率。你可以参考应用笔记AN283-PSOC®1感测频率。
以上来自于百度翻译 以下为原文 "Slotted" optocoupler device and a optical sensor (which usually employs IR LED and photodiode as discrete devices) are same; the only difference is that the slotted optocoupler comes in a single package. To measure the speed, you need to record the frequency of the pulses coming from the optical sensor. You can refer application note AN2283 - PSoC® 1 Sensing - Measuring Frequency. |
到目前为止,我们知道的应用是线性速度传感,或RPM角速度。
这么多问题没有回答,时间太少了…… 开槽的应用,磁盘或标签附件,平衡,正交或不,速度限制, 总线或电流回路或……要考虑。 问候,Dana。 以上来自于百度翻译 以下为原文 So far we know application is linear speed sensing, or RPM angular rotation speed. So many questions unanswered, so little time........... Slotted application, disk or tab attachment, balance, quadrature or not, speed limitations, buss or current loop or......to consider. Regards, Dana. |
寄给我一些基于传感器的材料?
光电微传感器? 以上来自于百度翻译 以下为原文 send me some materials based on ptical sensor? and photo micro sensor? |
754个成员聚集在这个小组
加入小组2106 浏览 1 评论
1853 浏览 1 评论
3671 浏览 1 评论
1788 浏览 6 评论
1536 浏览 1 评论
572浏览 2评论
424浏览 2评论
438浏览 2评论
386浏览 2评论
916浏览 2评论
GMT+8, 2024-12-25 16:54 , Processed in 1.390355 second(s), Total 98, Slave 82 queries .
