过去我用MPLABX使用好奇心板,没有问题。然而,我刚刚插入了新的HPC板,我不能选择好奇心板作为一种编程工具。它会出现在选项中(没有序列号,但“好奇”弹出),但我在物理上无法点击它。当我拔出板时,使用好奇板的选项将在MPLABX中消失,所以我知道它正在看板。见附图PictReSun-MPLABX,启动一个新项目& GT;独立项目& GT;选择一个设备& GT;&在“微芯片起动器工具包”下面看好奇心板应该在哪里。这是我粘贴的屏幕。这是我的MPLABX产品版本的信息:MPLAB X IDE V4.05Java:1.8 0144;Java热点(TM)64位服务器VM 25.144-B01Run
time:Java(TM)SE运行时环境1.80y144-B01Stase:Windows 10版本10在AMD64上运行;CP1252;EN(MPLAB)
以上来自于百度翻译
以下为原文
I've used the Curiosity board with MPLABX in the past with no problems. However, with the new HPC board I just plugged in I can't select the Curiosity board as a programming tool. It will show up in the options (no serial # but 'Curiosity' pops up) but I physically cannot click on it. When I unplug the board the option for using the Curiosity board will go away in MPLABX so I know it's seeing the board. See attached pictures
Open MPLABX, start a new project>>stand alone project>>pick a device>>look under the 'Microchip Starter Kits' where the Curiosity board should be. This is the screen I'm stuck on.
Here's the info on my version of MPLABX
Product Version: MPLAB X IDE v4.05
Java: 1.8.0_144; Java HotSpot(TM) 64-Bit Server VM 25.144-b01
Runtime: Java(TM) SE Runtime Environment 1.8.0_144-b01
System: Windows 10 version 10.0 running on amd64; Cp1252; en (mplab)
Attached Image(s)
