例子: 带使能信号和复位信号的加法器,由matlab给输入数据addin,en。 错误: VHDL仿真结果貌似是正确的,但是verilog语言仿真的结果addout应该延时输入的addin一个clk,为什么没有延时呢。!! 1. VHDL语言: LIBRARY ieee; USE ieee.std_logic_1164.all; use ieee.std_logic_arith.all; use ieee.std_logic_unsigned.all; entity test is port ( rst_n : in std_logic; clk : in std_logic; en : in std_logic; addin : in std_logic_vector(11 downto 0); addout : out std_logic_vector (11 downto 0) ); END test; architecture rtl of test is signal add1 : std_logic_vector(11 downto 0); begin process(clk,rst_n) begin if rst_n ='0' then add1<=(others=>'0'); elsifclk'event and clk = '1' then if en = '1' then add1<=addin+'1'; else add1<=add1; endif; end if; end process; addout<=add1; end architecture; 2. Verilog语言 module test (clk, rst_n, addin, en, addout ); input clk; input rst_n; input en; input [11:0] addin; output [11:0] addout; reg [11:0] add1; assign addout=add1; always @ (posedge clk) begin if (!rst_n) begin add1=12'h0; end else if(en) begin add1=addin+1; end end endmodule
这是我给的m文件,即输入的激励:
function [iport,tnext] = test(oport, tnow, portinfo) tnext=[]; iport=struct(); persistent inc; persistent rst; CLK_PERIOD = 1e-8; RST_MUL_TIME = 5; RST_TIME = RST_MUL_TIME * CLK_PERIOD; if isempty(inc) inc=0; iport.addin=dec2bin(0,12); iport.en=dec2bin(0,1); end inc =inc+1; if tnow <= RST_TIME rst = dec2bin(0, 1); inc=[]; else rst = dec2bin(1, 1); end if inc>=10 iport.addin=dec2bin(inc,12); iport.en=dec2bin(1,1); end if 30==mvl2dec(oport.addout) iport.en=dec2bin(0,1); end iport.rst_n=rst; end |
1500 浏览 1 评论
助力AIoT应用:在米尔FPGA开发板上实现Tiny YOLO V4
1072 浏览 0 评论
2584 浏览 1 评论
2270 浏览 0 评论
矩阵4x4个按键,如何把识别结果按编号01-16(十进制)显示在两个七段数码管上?
2541 浏览 0 评论
2023 浏览 55 评论
6037 浏览 113 评论
GMT+8, 2024-12-28 07:40 , Processed in 0.559821 second(s), Total 72, Slave 54 queries .
